a mate fitted the agila column to his kit car with a Peugeot v6 and got it working properly so I figured it would work with the m/s . Hi there, sorry to drag up an old thread. I am intending to fit an Agila column in a Fulvia (I have the column), and found this conversation. The colour coding on the Agila controller is different to the Corsa B & C, to save me a load of age, I don't suppose you know / remember the colour coding do you? It has the two heavy main supply cables, plus 6 thin signal ones, White/Orange | Blue/Red | Grey | Brown/Yellow | Purple | Black/White. Any help would be much appreciated. Jon Fuller PS. I will be sending it proper speed signal etc, not the twiddly knob nonsense
Last Edit: May 18, 2017 9:02:15 GMT by jonfuller
froggy
Il take some pics tonight when I get home .
You're a star, thank you
May 19, 2017 18:20:39 GMT
Il take some pics tonight when I get home . Any joy with the wiring colour keys Froggy? Jon
froggy
May 19, 2017 20:20:00 GMT
The two thick wires are the 40a fused supply and earth and you can see the three tied off and unused . Bl/w is switched ig live , purple is speed signal and the brown/yellow is rpm . If your colours are different they should go to the same pin position as I had to replace the Ecu on mine after gettting water damaged and I cut the harness to get the Ecu and the colours were different to mine but worked fine
Thanks Froggy, that's a massive help Much appreciated. Jon
