stevietuck
Never argue with idiots,they drag you down to their level then beat you with their expertise!
Sept 29, 2015 14:47:30 GMT
baggabones I do like the grey, but after saying the red looks poo, I keep going back to that pic and just staring at it, thinking, you know what maybe in a different shade of red! Iv'e just said to my girlfriend, that I don't think I will be happy till Iv'e painted them red and don't like it
jonxs
Sept 29, 2015 15:13:37 GMT
What about red lip and black\grey faces?? That's the best of both right??
stevietuck
Sept 29, 2015 16:22:45 GMT
jonxs I really want to polish the rims, just cos!
jonxs
Sept 29, 2015 16:28:15 GMT
jonxs I really want to polish the rims, just cos! Well, what about red faces and a polished lip We all like shiny things
stevietuck
Sept 29, 2015 16:40:20 GMT
Yeah thats what I'm thinking
niwid
Sept 29, 2015 16:52:44 GMT
Remember that the car will be lower, with chunky bumpers and what not. Also tyres will make a difference. Red couldbwork, but that shade looks too bright
gazz81
Sept 29, 2015 17:02:43 GMT
don't forget polished rims are an to keep looking nice! I like black with a red rim.
stevietuck
Well folks, I now have two wheels ready for paint , but in doing so I have managed to sand half of my thumbnail off! I decided to have a brake from the wheels, to give my thumbnail a chance to grow back and because I was getting a bit fed up. I have been spending some time looking at red paints and found these that I really like.. deep red candy.. and this, cherry candy.. Thing is I know nothing about painting, but would I be right thinking that candy paint needs to be applied over a base coat? but what colour base coat? also how much paint am I going to need to do 4 wheels? The candy paint costs £10 a can then if I'm right I will need primer, base coat and clear coat , so my cheap wheels are getting more and more expensive lol! Anyway with my sanding thumb injured I cracked on with cleaning up some more suspension stuff. Got the wishbones wire wheeled primed and painted, same with drop links and anti roll bar clamps. From this. to this.. Next I did the subframe, once I had wire wheeled it I noticed this.. see this bit, think its an engine mount. Well it should bolt on and off, but it has been welded up at the side and underneath like this... Now I could just grind out the welds and remove it that way, but I was wondering why it has been done at all? it would have been much easier to bolt on a new mount if it was worn or damaged, but it doesn't look worn or damaged. The subframe came from a track car so is this a common mod to stiffen things up? should I leave it on? I left it on for now and gave the whole subframe a going over with the rust killer. Today I am going to meet Oscar my new grandson, so no tinkering till Sunday. Thanks for looking Steve.
stevietuck
Oh forgot to ask, is there any difference between gti and standard steering racks? Cheers steve
smart
Well folks, I now have two wheels ready for paint , but in doing so I have managed to sand half of my thumbnail off! I decided to have a brake from the wheels, to give my thumbnail a chance to grow back and because I was getting a bit fed up. I have been spending some time looking at red paints and found these that I really like.. deep red candy.. and this, cherry candy.. Thing is I know nothing about painting, but would I be right thinking that candy paint needs to be applied over a base coat? but what colour base coat? also how much paint am I going to need to do 4 wheels? The candy paint costs £10 a can then if I'm right I will need primer, base coat and clear coat , so my cheap wheels are getting more and more expensive lol! Starting from scratch with candy paint is very expensive. Because of the type of paint you have to use their brand of primer, their basecoat + candy + Lacquer so to buy enough to paint 4 wheels would be expensive!
1998 Rover 400 Derv
stevietuck
Thanks for the input smart. Well if I were to buy 1 can of each of their primer, base, candy and clear coat it would cost £52, so at a very minimum I would need 2 cans of each? so thats £104 (more than the wheels cost) Think I'm going to have to find a cheaper option! How does a normal metallic paint work? is it just primer, paint then clear coat?
This is a bodge... nothing more. Chop out, and refit as per standard. Most likely had a dying upper mount, and thought the excessive movement was due to the lower steady being "loose"
Oh forgot to ask, is there any difference between gti and standard steering racks? Cheers steve As far as I know, if it's standard non-pas its the same, about 3.9 turns lock to lock afaik. I THINK a pas rack is 3.2 turns. There are 2 different fit drives however, square and splined. Liking the progress on this btw! Seem to be more and more base models getting attention these days.
1989 Peugeot 205 XE - Gone to the scrappy in the sky, sad face.
1993 Mazda MX5
stevietuck
Thanks for the input guys. chairchild I thought it might be a bodge, will grind it off later jackmorris did a bit of googling last night, your right about the 3.9 turns on non pas rack, so may as well stick with the one on the car. I will check to see what type mine is ( square or spline ) then either keep the other if its the same or get rid if not. Cheers steve
smart
Thanks for the input smart. Well if I were to buy 1 can of each of their primer, base, candy and clear coat it would cost £52, so at a very minimum I would need 2 cans of each? so thats £104 (more than the wheels cost) Think I'm going to have to find a cheaper option! How does a normal metallic paint work? is it just primer, paint then clear coat? Yes is the answer to your metallic paint question. You won't get great finish with rattle cans but there's plenty of videos online to help
1998 Rover 400 Derv
Keep up the good work, like the old 205,s....
stevietuck
Well the weather has really turned poo up here, but I managed to get the subframe and anti roll bar painted. No pics cos its all piled in my shed, will get some once the rain stops. I also got the other strut painted, this time I tried the hammerite without primer to see if it went on any better since it says on the tin "no need to prime paint straight on to rust" . It still went on poo, but it had been treated with rust killer, that is also a kind of primer so me being me thinks ok, I will do exactly what the instructions say, so I wire brushed a strut top that I wont be using and painted the hammerite straight on, and it was still poo! So my official verdict on hammerite is jobie, jobie, jobie! I will have to give it 2/10 because on the tin it says it was red paint and it was red, but I'm not convinced its paint! I have also just ordered a pair of strut top bearings, so once they arrive I can build the struts back up, and once thats done I can stick these on .... I found them on spanish ebay and couldn't resist since they only cost a couple of euros. Cheers for looking steve.
stevietuck
Oct 10, 2015 15:56:13 GMT
Well today I was hoping to get some time spent on Doris stuff, but then my mum came to visit followed by my girlfriend's mum, so only had a couple of hours. I started off by applying paint striper to the other two alloys, then I had to move them into the shed cos the dogs decided they wanted to sniff them! Then I moved on to the gti valence, I had already had a bit of a go at sanding it and it looked like this. I gave it a bit more of a rub down then gave it a coat of plastic primer .. it had a bit of a reaction in a couple of places like this... and this... I think this could have been because of me putting too much paint on. Anyway I will leave it the 24 hours that it says on the can then give it a rub down and add a bit more. Next I scraped of as much paint as I could from the alloys and gave them a rinse off. My thumb nail is almost grown back now so I might have a bash at them tomorrow. It would be nice to get them both looking like this ... by the end of Sunday. Thing is once all four are ready for paint I'm going to have to make up my mind what colour to paint them. I'm still on red but still considering a dark grey. Black with red wheels, now where have I seen that before? Oh yeah I know!! Oh and here is the subframe painted.... That's about it for the day , thanks for looking. Steve.
Oct 10, 2015 16:47:25 GMT
Have you not learnt yet that when parents/ inlaws visit they have to muck in?....should've got em sanding
stevietuck
Oct 10, 2015 16:52:01 GMT
