edk83
Had a local welder / fabricator come have to look today, looks like its on!
I will crack on with taking off the Allegro suspension etc Just been taking off ball joints before it started raining, the top one is stuck on the passenger side and the bottom one on the drivers side! Fun times.
Also had a closer look at my TF frame, the rear subframe mounts can go in two places, on a metro they go higher up than on the mgf - how handy is that, two places custom mounts could go!
Watching this with much interest! Best of luck..this gonna be cool! :-)
Did you buy that Rover off a lad called Matt in Erdington?
edk83
I did!
Small world, used to work with him. Recognised the reg.
edk83
Indeed, I don't think he had it long but he changed the headgasket. Seems solid so far, done about 800 miles in it now, can't complain for a £200 donor car.
Still looking for an mgzr, almost bought one today but it went up a bit more than I wanted to pay, lots about though.
Tried a Volvo alloy on the Allegro, looks daft!
Last Edit: Jul 5, 2017 15:30:17 GMT by edk83
edk83
No more messing! Picked this up last night
Also finished removing all the suspension and arms, came out pretty easy!
Last Edit: Jul 5, 2017 15:35:43 GMT by edk83
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Mar 11, 2015 18:08:48 GMT
Keep the updates coming pal.
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
edk83
Mar 18, 2015 21:05:47 GMT
Picking up an mgf vvc on Saturday It's had a complete top end engine rebuild in the last few years too.
I found that by using an mgf I'd have a hydro clutch, driveshafts and the front brakes.
Would just need a 52mm throttle body, gear linkage and I'm away (kinda) !
Mar 18, 2015 22:40:35 GMT
Excellent project. Have got quite a soft spot for Allegros these days and wondered how much of a job a K series transplant would be.
Bookmarked and following with great interest.
1964 Saab 96 two Stroke 1971 Hillman Avenger 1500 GL (Tuned 1600 fitted) 1976 Saab 99 2dr EMS (Project of very slow progress) 1978 Saab 99 2dr EMS (Awaiting reshell) 1981 Saab 99 2dr Turbo (Awaiting reshell)
ftz313
Excellent project.
Out of interest, in my experience the edis you have is off the ohv fiesta/escort 11/1300's. I did some back to back testing with one of these and the later cvh esc out of mk3/mk5 escorts on a zetec (nearly 14 years ago now ouch).
I believe the cvh one to been so, so much better as I reckoned the red edis thingy had an advance curve that was more pretty lame as it was designed to stop the ohv's from being revved.
Anyway I always pass on this info when I can.
Top project and if I was closer I'd volunteer to help fabricate it all for pennies. :-)
edk83
Mar 19, 2015 21:21:07 GMT
I was running it on the red esc module, once it was running it was certainly better, more power.
Cold starts were hard work though, took a lot more turning over to get it to fire.
Not sure if it was just the bike carb setup.
edk83
Mar 22, 2015 14:11:58 GMT
Well I got the mgf, drives nice and straight, runs very well, nice and smooth.
Only problem is the ecu seems to be limiting the rpm to 5800rpm so no vvc at the moment!
I'm hoping its just the cam sensor. Tried leaving off the battery and reseating the connector but no joy.
All the other connectors seem correct, whats the best way to diagnose it? its not obd2!
ed325i
Mar 22, 2015 18:05:27 GMT
I had Triumph stag alloys on mine they look nice. Ed
edk83
Mar 22, 2015 23:24:54 GMT
It currently has stag wheels on it, powder coated white, looks good but they wont fit metro hubs. Looks like it will end up with mgf wheels.
edk83
Apr 18, 2015 18:56:10 GMT
engine out today!
Last Edit: Jul 5, 2017 15:39:35 GMT by edk83
retrolegends
Apr 19, 2015 13:47:34 GMT
Watching with great interest.
edk83
Apr 26, 2015 20:17:11 GMT
I got water pipes from a front engined car today, also got gear linkage, with a Rover 200vi attached to them! Only problem is this is now my driveway! Anyone want a Rover 114gsi, needs a new home?
Last Edit: Jul 5, 2017 15:41:15 GMT by edk83
edk83
Bye bye MGF!
Last Edit: Jul 5, 2017 15:41:58 GMT by edk83
Kieran
How many engines and gearboxes have you got now?!
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
