sleag40
I've no longer space for any more!
So far this year the only component to give up was a front wheel bearing. It took me most of the day to fix it due to arthritis related restricted mobility, but got it done with enough time left for a decent ride out. Still scrubs up well.
1994 Volkswagen Polo G40 1992 Volkswagen Polo G40 1988 Vauxhall Cavalier GLi 1977 Vauxhall Cavalier GL 1967 Lambretta SX200 1966 Lambretta TV200 1964 Lambretta LI150
iant
Just read this whole thread and loved it. These are lovely, a credit to you.
My first car was a 1984 Polo Classic 1.3 in Silver with a blue interior. I once viewed a G40 to replace it but it was far from honest and would have given me no end of trouble!
Ian
sleag40
This got its annual service and wax polish recently. Afterwards it got a decent ride out while the weather was still nice. Autumn proper has finally landed now, so may not get another go for a while.
sleag40
Dec 17, 2023 15:19:49 GMT
Attended to a few jobs on this while it's immobilised by saltiness. First up was the load compensator valve - it seized up some time this year, highlighted by less than normal brake effort at the last MOT. Car goes up. Easy enough job, made easier by one of those pressure bleeders that utilises an inflated tyre as a source of air pressure. Job done. Next was the in tank fuel pump, after the in-line pump became noisy, this was suspected as the cause. Another easy job, access is through a removable panel under the back seat, now fuel delivery is quiet again. 🙂 Whilst having a good look around while it was up in the air, I noticed that the (original) radiator had started to fail, leaving pinkness as a witness. Unable to buy a genuine one now, I settled on a Nissens one - I've been using one on the grey car for years. Car goes up again. Radiator, intercooler and charger outlet all came off. Removed bits cleaned up before going back on. The job was then let down by Royal Mail's "24hr" service, which after 72 hours still hadn't materialised.
sleag40
Dec 17, 2023 15:25:17 GMT
Post man came next day. Stuff went back together. New radiator and clean intercooler brighten up front end view. Some pre 2001 font number plates should arrive tomorrow. I've been meaning to address the inappropriate plates ever since the car went back on the road nearly ten years ago. 😀
sleag40
Dec 23, 2023 16:20:36 GMT
Cam belt and water pump coming off. First, the wrong parts arrived. Once the right bits arrived, it all went back together. Correct age appropriate plates flung on. Much better!
