Sept 19, 2014 19:53:32 GMT
I've got a long term plan to do a turbo conversion on a car. Pretty straight forward stuff-carb I've already got sorted, manifold isn't much of an issue, neither is the oil supply for the turbo. What I'm struggling to get my head around is to sort out the ignition timing for when it's on boost & where I'm hoping someone might be able to help?
As I understand it needs to be adjusted to retard the ignition timing as the boost increases, but how can this be done with a car that doesn't have an ECU of any sort? It's very basic engine design running a very basic distributor with vacuum advance.
Any advise very gratefully received!
sparkyt
selling stuff
Sept 19, 2014 20:07:10 GMT
It's easy bud just go find a dizzy from a Saab 900 trbo .. dizzy in block type ..
Then take the vac unit off and fit it to your dizzy ..
Simple ..
Your dizzy will advance untill it starts to see boost then it will retard ..
sparkyt
selling stuff
Sept 19, 2014 20:11:39 GMT
This is beetle dizzy with Saab vac unit fitted
Sept 20, 2014 7:34:08 GMT
Now that sounds very interesting, thank you for that. I'll try & source one & give it a go. Is it really as straight forward as that?
Adey
Club RR Member Number: 171
Sept 20, 2014 19:38:25 GMT
There are also other cheap mappable ignition only systems out there, you could also try wiring in an aei off a renault 5 gtt same thing but the advance and retard is built into the coil rather than the dizzy but it would then need a specific trigger pick up.
pepe
Sept 22, 2014 12:18:05 GMT
I'm going to use the twin port vacuum canister on my supercharged carb build, been used a few times by all accounts, what carb are you using just out of interest? I'm looking for a r5 gtt carb and fpr at the moment!
Sept 22, 2014 14:19:38 GMT
I've got a very early diahatsu turbo carb, so it bolts straight to the original toyota inlet manifold-just needs re jetting to suit, but even they swap out from the toyota 5k carb (or so I've been told) It's a very long term project & a little knowledge can be a dangerous thing, so want to get all the info I can before I get stuck into it properly.
pepe
Sept 22, 2014 16:16:50 GMT
ok cool well if needs be you can always drill the old jets out to desired size! sounds intersting! got a build thread? what car/engine is it?
Last Edit: Sept 22, 2014 16:17:35 GMT by pepe
Sept 22, 2014 20:35:35 GMT
NO build thread yet-I'll wait until I know I'm going to get stuck in to it. It's one of my Starlets, did an engine swap, so it's now a 1500 instead of the original 1.0 with a custom Kent cam, bit of head work, but nothing huge. Turbo conversion just seems like something fun to try as I've got a screamer in my other car.
pepe
Sept 23, 2014 12:35:46 GMT
Exactly why I'm doing it! For the fun of it and basically the vw scene is Abit samey, so I thought I'd switch it up abit, I've been told numerous times not to bother put an Abf/KR gti lumps in blah blah but I'm not too fussed what power it makes aslong as it works looks as OE as poss and its reliable that's the main thing for me, been pretty cheap so far aswell! Not even £300 in and all I need is carb, fpr and sort out piping! And £240 of that went on a fresh 0 mile g-lader charger
pepe
Sept 23, 2014 12:37:44 GMT
Also if you have a solex/pierburg carb and need some info let me know what model and I'll see id I can help you as I have the pier burg/solex Haynes book!
Sept 25, 2014 21:02:04 GMT
Thanks for the offer, but it's an Aisin carb, so not very well known & to be honest not the greatest-but it's what I've got & I'm going to work with it! Knowing me it'll be years rather than months before it's sorted, but I'll get there.
pork
Sept 25, 2014 21:23:59 GMT
I welded my dizzy, the piece that the weights spin out into, I just reduced the space they have to move out into, left the vac advance on too
Aldon amethyst do somthing that can be adapted to fit a standard dizzy, and can be programmed by laptop (I think)
pepe
Sept 26, 2014 0:00:16 GMT
what do you mean welded the dizzy how?
sorry i cant help you with the aisin carbs dude!
pork
Sept 26, 2014 5:57:59 GMT
Was like this Then after welding
pepe
Sept 26, 2014 7:57:03 GMT
does the timing just stay retarded then after locking the dizzy? how do you set idle timing by turning dizzy body?
Last Edit: Sept 26, 2014 8:03:03 GMT by pepe
pepe
Sept 26, 2014 8:23:40 GMT
also would it be a good idea to remove the springs and weld it in the fully advanced position so that if the weld break it doesnt fly into fully advanced position and potentially damage the engine?
pork
Sept 26, 2014 15:38:25 GMT
does the timing just stay retarded then after locking the dizzy? how do you set idle timing by turning dizzy body? Yeah. Worked fine for ages, but gone with ecu and injection now
doobie
Sept 26, 2014 18:02:39 GMT
If the system is the same as the turbo mini blow through you will also need a fuel pressure regulator that increases with boost....
pork
Sept 26, 2014 18:30:40 GMT
Yup, used that with my turbo bike carb build.
Boost referenced fuel reg, 1 bar fuel pump, Welded up dizzy,
