MiataMark
Club RR Member Number: 29
Nov 25, 2018 12:00:40 GMT
Well I've got a new job, 2 actually but that's another story, and I've probably over committed myself! But motivation for doing car related things has disappeared not helped by the weather and lack of garage. Also I had to replace a door mirror glass on the Discovery after a woman couldn't judge clearance and took the door mirror out and now the Alfa is making gearbox noises (known weakness in bearings), I at least need to change the gearbox oil. I really need to get the handbrake on the MX5 sorted and loosely bolt the new wings on then get it down the body-shop, anyway as it was Black Friday (not that I particularly like the idea of mass commercialisation) I did venture on to the MX5parst website; Do I need them not really but why not and they look good #becauseracecar I was actually expecting them to be braided and shiny but performance is what matters and I got stickers! Also some time ago I bought some LED amber and white lights to use as indicators/side-lights and clear repeaters with bulbs (I want to get rid of the repeaters in the wings). Hopefully getting some more consultancy type work which will mean more budget available (unless it gets spent on the Alfa or an Alfa replacement, ummm S-type Jag with petrol V6 that could find its way into the MX5 with a Rocketeer conversion).
Last Edit: Nov 25, 2018 15:38:31 GMT by MiataMark
MiataMark
Apologies for another diversion into Alfa land...
Had to drive to Carlisle a couple of weeks ago (that's 275 miles away for me) long painful journey up the M5/6 with some longish stretches using cruise control in 6th*. When I got back my wife used the car and rather gleefully said it's making funny noises, sure enough bearing noises from gearbox. Internet research reveals known problems with the M32 gearbox (also used on various Vauxhall's and Fiats). More internet research reveals a specialist in Halifax that can repair them in situ for a reasonable (still a lot) cost. Don't use the car in case it makes it worse. Yesterday get up early to drive to Halifax (only 211 miles), just up the road can't get 5th or 6th carry on as I thought that's just the bearings, arrive at garage bang on time at 9:30 (told you it was an early start), drove there in 4th. Very quick chat and test drive, gearbox knackered! I had at least arranged a business meeting in Leeds so I can claim the mileage back as an expense (self-employed). Long slow careful drive back (M62, M1, M69 Fosse Way) using 4th.
*this is what probably did for the gearbox, the shaft for 5th/6th doesn't get lubricated and the torque of the engine kills the bearings. Being lazy and using cruise instead of changing down exacerbates the problem.
So now do I pack it in and sell for parts but what do I buy then (not the Jag mentioned above the Rocketeer conversion is £6K without engine), or get a second-hand gearbox (£300 <50K 3 month warranty) plus DMF flywheel and clutch plus fitting (~£800)
and all the time the MX5 is looking sad and naked on the drive, think I might put some Christmas lights on it :-)
TBH I'll almost certainly repair it there isn't much left that can go wrong with it, apart from turbo, electrics...
Last Edit: Dec 11, 2018 11:40:07 GMT by MiataMark
Ian
Dec 11, 2018 11:07:08 GMT
I can feel your pain, Our old 2006 Astra exploded its 6th gear out the side of the gearbox, managed to get it home with a hole in the casing some 30 miles though. Gearbox was then rebuilt and a new DMF and clutch fitted, which cost quite a lot but my better half really liked the car even though it had 195k miles on it.
2 months later the cambelt snapped
3 years later its still sat on the drive broken and she doesn't want to get rid of it.
MiataMark
Dec 11, 2018 11:37:07 GMT
I can feel your pain, Our old 2006 Astra exploded its 6th gear out the side of the gearbox, managed to get it home with a hole in the casing some 30 miles though. Gearbox was then rebuilt and a new DMF and clutch fitted, which cost quite a lot but my better half really liked the car even though it had 195k miles on it. 2 months later the cambelt snapped 3 years later its still sat on the drive broken and she doesn't want to get rid of it. Cam-belt snapping was last years Christmas present! Bought a gearbox, £480, delivered, warranty, from a 70Kmile car, the £300 gearbox was for a petrol with wrong ratios, diesel ones are rarer. DMF and clutch will probably run to about £350 and then there's fitting.
Dec 11, 2018 11:58:47 GMT
So now do I pack it in and sell for parts but what do I buy then (not the Jag mentioned above the Rocketeer conversion is £6K without engine), or get a second-hand gearbox (£300 <50K 3 month warranty) plus DMF flywheel and clutch plus fitting (~£800) TBH I'll almost certainly repair it there isn't much left that can go wrong with it, apart from turbo, electrics... TBH this is why I drive a new-ish VW transporter for work, I was never very good at selling vehicles before I had to spend loads of money... then would sell them eventually for the new owner to enjoy years of trouble free motoring... Now I treat my van as an asset and try and move it on before it losses all of its value or costs me more than servicing. But of course, competent as the van is, it’s not interesting or fun to drive... Anyway, good luck!
Ian
Dec 11, 2018 16:26:48 GMT
I can feel your pain, Our old 2006 Astra exploded its 6th gear out the side of the gearbox, managed to get it home with a hole in the casing some 30 miles though. Gearbox was then rebuilt and a new DMF and clutch fitted, which cost quite a lot but my better half really liked the car even though it had 195k miles on it. 2 months later the cambelt snapped 3 years later its still sat on the drive broken and she doesn't want to get rid of it. Cam-belt snapping was last years Christmas present! Bought a gearbox, £480, delivered, warranty, from a 70Kmile car, the £300 gearbox was for a petrol with wrong ratios, diesel ones are rarer. DMF and clutch will probably run to about £350 and then there's fitting. Think we spent £1800 all in for the gearbox refurb, new casing, new flywheel clutch and an oil change. Its no fun is it, I do hate cars sometimes! The replacement car suffered an siezed oil pump at 97k miles, so we had a recon engine fitted, at the same time it seemed silly not to put a new flywheel and clutch on it £3k later it was fixed. Maybe we should have moved away from Vauxhall diesels!
Last Edit: Dec 11, 2018 16:29:05 GMT by Ian
Dec 11, 2018 16:38:27 GMT
What a shocking gearbox that M32 is, GM should hang their head in shame! mind you if the one you have bought has done 70k that's probably near the end of its life as well, there is a place in Essex I think that's meant to be good for rebuilds on these boxes
MiataMark
Dec 11, 2018 16:45:11 GMT
What a shocking gearbox that M32 is, GM should hang their head in shame! mind you if the one you have bought has done 70k that's probably near the end of its life as well, there is a place in Essex I think that's meant to be good for rebuilds on these boxes The place I was going to use was A & S Clutch Technology in Halifax they have got some good reviews/recommendations on various forums. Yeah installing a 70K mile replacement is a risk but overfilling to 3ltr is meant to work well. Failing that it's get the car running and sell it :-) This gearbox went at 96K so hopefully get another 20K out of the replacement.
Dec 11, 2018 16:56:27 GMT
Ive heard using a thicker oil can help, the original oil is so thin its like water and doesnt stay on the bearings! you did well with 96k ive seen them go at 16k and GM would still wriggle and squirm about coughing up the cash to fix them!!
The thing that will wind you up more is they were chucking new M32 diesel gearboxes out at one of the main GM spares warehouses!!
MiataMark
Dec 11, 2018 17:08:15 GMT
Ive heard using a thicker oil can help, the original oil is so thin its like water and doesnt stay on the bearings! you did well with 96k ive seen them go at 16k and GM would still wriggle and squirm about coughing up the cash to fix them!! The thing that will wind you up more is they were chucking new M32 diesel gearboxes out at one of the main GM spares warehouses!! Interesting comment about oil, I read the reason is that the shaft for 5th/6th is at the top of the gearbox and only lubricated by splash (I'm sure there's a technical term) hence the recommendation to overfill to 3ltr and use good quality oil (e.g. Red Line MT 85 75W85 GL4) I did buy the best oil listed in ECP, Castrol Syntrans Multivehicle 75W90. Yes that last comment winds me up :-)
Dec 11, 2018 17:23:22 GMT
Might be worth chucking some Lucas gear oil stabiliser in too MM.
MiataMark
Dec 11, 2018 17:30:43 GMT
Might be worth chucking some Lucas gear oil stabiliser in too MM. That's definitely worth considering thanks for the info.
Dec 11, 2018 18:15:15 GMT
I can feel your pain, Our old 2006 Astra exploded its 6th gear out the side of the gearbox, managed to get it home with a hole in the casing some 30 miles though. Gearbox was then rebuilt and a new DMF and clutch fitted, which cost quite a lot but my better half really liked the car even though it had 195k miles on it. 2 months later the cambelt snapped 3 years later its still sat on the drive broken and she doesn't want to get rid of it. If your old astra is the 1.9 cdti that engine has sacrificial rockers. Upon timing going out the rockers snap. 9 times out of ten the valves don't touch the pistons. I would buy a set of rockers and a belt kit. May not be cylinder head off to fix
Ian
Dec 11, 2018 19:37:10 GMT
It is the 150 cdti, I thought as much, I just never had the time! Being sat outside for 3 years won’t have helped it’s cause though.
MiataMark
Dec 11, 2018 21:12:42 GMT
I can feel your pain, Our old 2006 Astra exploded its 6th gear out the side of the gearbox, managed to get it home with a hole in the casing some 30 miles though. Gearbox was then rebuilt and a new DMF and clutch fitted, which cost quite a lot but my better half really liked the car even though it had 195k miles on it. 2 months later the cambelt snapped 3 years later its still sat on the drive broken and she doesn't want to get rid of it. If your old astra is the 1.9 cdti that engine has sacrificial rockers. Upon timing going out the rockers snap. 9 times out of ten the valves don't touch the pistons. I would buy a set of rockers and a belt kit. May not be cylinder head off to fix If that's the same as the Alfa 1.9 JTDm 16v engine then when my cam-belt went it only took out the rockers didn't damage the valves, oh and the glow plugs but at least one wasn't working anyway.
Dec 11, 2018 22:19:51 GMT
If your old astra is the 1.9 cdti that engine has sacrificial rockers. Upon timing going out the rockers snap. 9 times out of ten the valves don't touch the pistons. I would buy a set of rockers and a belt kit. May not be cylinder head off to fix If that's the same as the Alfa 1.9 JTDm 16v engine then when my cam-belt went it only took out the rockers didn't damage the valves, oh and the glow plugs but at least one wasn't working anyway. Yes its the same fiat derived engine. The joys of part sharing in the modern automotive world! The french and the italians supply around 60% of the markets diesel engines!
Ian
Maybe I should take a look under the rocker cover, page it can wait until spring! It needs new brakes and tyres now at least anyway, and some moss removal.
It still has original turbo and exhaust at 195k miles. Lots of EGR valves and alternators though.
Shame the 2.0cdti has a fault on the earlier ones with the oil pump...
MiataMark
Final tally on the gearbox repair;
£470 second-hand gearbox (has done 70K so will probably fail soon*), £870 for fitting including new DMF and clutch both were pretty very worn. The gearbox actually had a hole in the casing.
So in the last year I've spent about £2.5K on it and it's worth maybe £3k on a good day, think I really need to address my man-maths (I do know the figures for the MX5 but chose to ignore them).
At least now I can concentrate on the MX5...
* I have had it filled with 3ltr of good quality oil and will probably add the additive as mentioned by @quatermass as well as changing the oil annually.
MiataMark
Feb 26, 2019 14:46:33 GMT
I've been keeping away from RR since Christmas, I hate to think what @quatermass has been getting up to in the NAUGHTY CORNER! What with work issues, bad weather, and a general lack of motivation (car or otherwise) I've not touched the MX5 since the summer. However I really need to get it sorted out one way or the other so I can actually drive it. It was sat on the drive with no handbrake cables, front wings, front and rear bumpers removed. Last weekend I got out there and retrieved the new wings I'd bought from under the car, thankfully they had survived being in the open wrapped in soggy cardboard, fitted them loosely, refitted the front bumper loosely (there's a theme here). This weekend, weather permitting, my aim is to replace the handbrake and (loosely) put the rear bumper back on. I also need to sort out the passenger sidelight/indicator as it was held together with putty! I did buy some LED side/indicator lights but need to make up some small brackets and different connectors. Then it can go to the body-shop to have the welding sorted out. May have found some barn space so I can do a bit of painting and sort out the front brakes, but the main thing is to get it back on the road so i can drive it.
I was hoping to have it back on the road by the RR Weekender, for the BNMAC stand, but not sure if that's possible. Quick question, it's taxed and insured but doesn't have an MOT (and would fail one at the moment) can I drive it to a place of repair (body-shop) who will also sort out an MOT when it's repaired?
The troublesome Alfa is being troublesome, having sorted out the gearbox, at great expense, a driveshaft is now wobbling (common fault apparently, sigh).
zeberdee
Feb 26, 2019 15:08:57 GMT
Quick question, it's taxed and insured but doesn't have an MOT (and would fail one at the moment) can I drive it to a place of repair (body-shop) who will also sort out an MOT when it's repaired? You can drive it on a direct route there for repair , as long as it’s pre booked with them & they have your registration number on their booking system . Hopefully you’ll get it back on the road soon .
