ali66
Jul 16, 2019 15:10:44 GMT
Jul 16, 2019 16:19:51 GMT
Its coming together nicely, the body looks really thick where you put the fuel filler through, is it that thickness all over?
Jul 16, 2019 21:22:26 GMT
Nice progress!
ali66
Its coming together nicely, the body looks really thick where you put the fuel filler through, is it that thickness all over? Thanks, it’s nearly there now! The thickness of fibreglass varies all over the body. It’s not like the lightweight front ends you see added to race cars. The thinnest area I’ve found is the firewall and the thickest being the wings where I cut for the fuel filler. I guess some areas are extra thick to help keep strength.
ali66
ali66
Seeing light at the end of the tunnel!
Is the engine lid curved on the corners and the body square? Looking good though
ali66
Is the engine lid curved on the corners and the body square? Looking good though Yes, well spotted! I’m going to fabricate some metal plate covers soon to neaten up the corners.
Nice update! I'm enjoying this coming together.
luckygti
I need to try harder!
Dec 14, 2019 10:15:41 GMT
Love it, really nicely done.
Dec 14, 2019 11:00:43 GMT
Are the wipers ok as they don't clear the centre section of the screen? I thought that was a specific requirement of the wipers for an MOT/BIVA test as on all cars I have seen the wiper arcs cross during use. Looks good a little like a Schwimmwagen with those headlight DRL's same designer Carman.
scimjim
Club RR Member Number: 8
Dec 14, 2019 11:28:05 GMT
I don’t think Karmann designed the schwimmwagen.
ali66
Dec 21, 2019 14:34:39 GMT
Yes they don’t clear the central section of the windscreen. Thanks for pointing this out though. I need to address this before getting it on the road. I was thinking some longer length aero blades might do the trick? What do you think? Nice photo by they way!
ali66
Jun 26, 2021 22:03:58 GMT
Coming together nicely! Will You keep that mix of chrome and flat black on the trim? I´d rather have them color coded to the body, maybe the bumpers in carbonfibre look, too. What was supposed to be mounted here?
Jun 27, 2021 12:43:19 GMT
What was supposed to be mounted here? There's an oval shaped cut out, with a rubber bag inside it, with a horn at either end.
ali66
ali66
ali66
Nov 10, 2021 16:19:44 GMT
Looks great! I've enjoyed following this along. Is there any way you can pull a mould off a Ghia and make yourself a removable hardtop? Would be a lot of work but make the car a lot more useable??
