retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
So aside from addressing the wings I've decided to put the old gal back together to get some use out of her. Correct rear number plate lights thanks to someone on the Allegro FaceBook page who was breaking a Mk3 Front spoiler cleaned up and given a coat of satin black. Bolted in place De-Chromed as it should look Bumper painted and fitted propearly And a pic taken outside the abandoned Dunlop factory up the road from me after a run out to make sure nothing falls off. 😆 Quite happy with the June '82 look, just need to get some OMD playing now!
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
vulgalour
Club RR Member Number: 146
Not going for the full wheel trims then? Not that it looks bad with the hubcaps and black bits.
retrolegends
Not going for the full wheel trims then? Not that it looks bad with the hubcaps and black bits. Not keen on the original trims tbh, I may go for black steels with MG Midget trim rings, long term I am thinking 14 inch banded steels. What do you reckon?
vulgalour
There's an Allegro estate on banded steels, I saw the picture recently and cannot refind it. All I can say is YES, it is a good look.
Not going for the full wheel trims then? Not that it looks bad with the hubcaps and black bits. Not keen on the original trims tbh, I may go for black steels with MG Midget trim rings, long term I am thinking 14 inch banded steels. What do you reckon? I'm not keen on the banded steels look - wide minilites would be my choice. How about late Mini Cooper ones?
vulgalour
Trouble with width is going to be the suspension so while you'll likely get regular Minilites on, wide ones are probably going to cause clearance issues at the back. They're 4x114.3 PCD so there's lots of choice at least, the tricky part is finding that nice balance of width and offset, what looks good on the back is often far too wide on the front with Allegros. It's a shame the really interesting Japanese wheels are so expensive, the Allegro is one of those cars that you can get away with putting really weird wheels on in a way you can't with something more mundane. These staggered Hayashi Talons (picture nabbed from an American 2015 advert) would look superb, though the measurements of 15x7 with a -2 offset may cause clearance issues.
Cosmics & D1's look nice on an Allegro
retrolegends
Is this the one you were thinking of vulgalour ? neilsdavies Minilites would look good tbh, I'll definitely consider them. Ultimately the best way forward would be to ditch the hydrogas suspension and have air ride, not sure the wife would approve though when it's the same price as a decent holiday! 😆
retrolegends
peteh1969 I reckon Cosmics look good on anything! 👍🏻
vulgalour
That's the very picture I was trying to find! To my eye that looks really right in that shot. The 1300 not so much because of that FWD offset problem of wide front track and no bodywork to cover the wheels, which is a shame because otherwise the Cosmics look right at home there.
retrolegends
Jun 24, 2017 11:12:25 GMT
retrolegends
Jun 30, 2017 16:58:57 GMT
I HATE cars!! I'm going to sell them all and buy a donkey!!!!
jamesd1972
Club RR Member Number: 40
Jun 30, 2017 17:08:38 GMT
Looks like a nice weekends work ! Keep your spirits up seen far worse.... James
vulgalour
Jun 30, 2017 17:27:47 GMT
It doesn't mention rust, so you're okay! Bit of a sod, all the same.
retrolegends
Jun 30, 2017 19:42:15 GMT
Tbh it's my own fault for taking it in such a state, I fixed the bonnet catch, number plate light and the battery bracket this afternoon and I've got a spare headlight although I can't figure out why he's put the screen washers as they are working perfectly. So just the big stuff to tackle! Your just the person I need for advice Mr vulgalour any ideas where I could get a set of radius arm bushes and are they the same as the prinny?
retrolegends
Jun 30, 2017 20:03:39 GMT
Looks like a nice weekends work ! Keep your spirits up seen far worse.... James Yep Ive got to take the positives.
vulgalour
Jun 30, 2017 21:04:41 GMT
Not sure which one you mean by the radius arm bush, can you show me a picture? As far as I'm aware, all the bushings on the Allegro are standard sizes so you don't need to get special Allegro specific ones and, I think, they are the same as Princess parts. I'm not entirely sure which parts exactly are shared between the two cars.
retrolegends
vulgalour
retrolegends
Thanks vulgalour they look the same, I've posted the question whether they are or not on the Allegro Facebook page.
