fer4l
Testing
Club RR Member Number: 73
Jan 19, 2014 22:47:58 GMT
Phil - final spec not certain yet, need to find an ECU (if anyone knows of one please shout, if we have to go for a new one it'll probably be a Ecumaster); we'll post up as soon as a decision is reached Mark - look forward to it, hopefully we won't hit too many hurdles timewise (famous last etc.!) Been a good weekend on the wheels front - picked up the Mustang wheels which have good legal tyres and will suit the sleeper look a treat, and for bling some Torque Thrust II alikes which I *think* should fit
pride
Jan 20, 2014 12:41:57 GMT
nice wheels , where you get them ? I am thinking bout ordering some similar ones from summit racing
fer4l
Testing
Jan 21, 2014 14:03:45 GMT
Hi Mark - wheels are from American Motor City in Epsom, bargainacious £450 the set inc lug nuts, socket, and centre cap, they were the last set but I'll ask whether he is getting / could get some more in In other news we're waiting on news of a test bore of the block to check that the 2 naughty bores will clean up OK at +030; fingers crossed!
drdick
Jan 21, 2014 19:18:58 GMT
Well, we have a final spec for the engine Simon at Real Steel has been a real help in working out what parts will work together well in what is a fairly obscure engine nowadays, and with a little imagination of our own and lots of calculations over Compression ratios and all sorts we've gone for Pistons at 410 + 030" (we nearly went 428 on the basis that if some's good, more's better and too much is just right, but there's a real risk of scrapping the block) - final capacity 6820cc Crank grind -010" Rods recircled Bottom end balance ARP rod bolts & head / rocker studs New oil & water pumps New high torque cam / lifters / cam bearings Pair of new Edelbrock ali cylinder heads (the old ones were v tired, & the cost difference is minimal) 600 Holley to keep things simple / get her up running and proven while we build up the EFi system Edelbrock ali crossplane inlet manifold (non-RPM, we're building for torque, power will be a by-product New flexplate and starter (a long story which I won't bore you with!) New dizzy (Mallory Electronic) Mustang alternator Tubular headers And then some subtle rocker covers and air filter to finish it off (and hide the EFi once it's in there) Have also ordered a front disc brake conversion kit, and pick up the Mustang wheels and tyres tomorrow Feels like progress, albeit mainly of the ordering shiny bits variety! Pics to follow when they arrive Cheers Matt PS if the Mrs is reading this it's a standard scrapyard engine dear! Only just come to this thread but this is an awesome car and that's gonna be an awesome engine. I bet the quote from RS was fun! So is it an FE engine or the earlier Mercury lump?
fer4l
Testing
Jan 21, 2014 21:07:19 GMT
Hi Dick (sorry to read about your Mustang btw and good luck with part deux Yep, the engine's an FE out of a 66ish Mercury. Still waiting news of the test bores like an expectant father! Hopefully all will be well and we can get cracking with the build - more as we have it Cheers Matt
fer4l
Testing
Jan 23, 2014 16:44:21 GMT
fer4l
Testing
Jan 23, 2014 16:49:58 GMT
And we'll know the scores on the bores tomorrow - been held up by a batch job it seems
fer4l
Testing
Jan 24, 2014 17:10:47 GMT
Anyone know the French for 4rsebiscuits?
CaptainSlog
Club RR Member Number: 180
Jan 24, 2014 17:53:00 GMT
buscuits de derière?
fer4l
Testing
Jan 25, 2014 23:37:17 GMT
Haha - that'll do, and thanks for translating! Sooo, as of Friday morning I was sworn that if this engine needed so much as an additional quid spent on it - that was it, it was scrap Then came the call... just one liner needed...oh, and a dip 20 seconds, 5 hundred quid. If I'd known at the outset what this engine would end up costing we'd have thrown a cutout in her ab initio, but given how much I've fallen in love with the old girl as we've stripped her down it has to be a resto Sooo...one in each hand and we forge on... here's hoping for no more nasty surprises! Cheers Matt
Jan 26, 2014 11:10:37 GMT
What pcd are your hubs? 5 inch.. Or smaller?....oh.. And it's a project that will just keep giving... And taking! ? ...i know!
59 Mercury wagon 64 Karmann Ghia 54 Porsche 356 Yamaha Rd350 Elsie 57 Berkerley He who dies with the most toys ...WINS!
Jan 26, 2014 11:11:07 GMT
fer4l
Testing
Jan 26, 2014 21:54:48 GMT
Hi MWM - Just been over for a gander at your wee beastie - stunning! We're on 4.5 x 5 - no idea of ET nor even what the difference between that and backspacing is, but order and hope, right?! If Amy turns out half as cool as yours I'll be a happy bunny and no mistake - I won't be going air, so can't hope for the same degree of lows though! Cheers Matt
Cheers... It's a big project... Never ending, but always worth it. Mines a wide 5 inch pcd, i can never find any wheels to fit, and i fancy a change!
mercmad
They sold those in Australia right into the 1960's . Is the engine a 352 or 390? . A guy here was giving away a pretty good 390 just before Christmas,as hes installing a 428 in his mustang restomod project. Are you going to add bags to the rear so you can tow ?
Last Edit: Jan 27, 2014 8:29:37 GMT by mercmad
Kroney
Jan 27, 2014 15:55:42 GMT
Lovely old bus. Shall I keep an eye out on the Cruise over the next couple of years, then?
Cheers... It's a big project... Never ending, but always worth it. Mines a wide 5 inch pcd, i can never find any wheels to fit, and i fancy a change! That's an odd PCD for a Ford. Only the '73 Thunderbird ran that. Jeep Cherokee ('99 onwards), Chrysler Voyager and various Chev's from the 70's/80's ran that. Check for 5x127 to find them.
5inch pcd, is what all the "full size" fords had...basically truck running gear under the car.... Hence it's not a popular wheel pcd option!
