Feb 26, 2014 23:42:55 GMT
Given the price of fuel in the UK, I'm not too sure that if I was smoking a big six drinking through triple Webers that I'd want the fuel gauge right in front of my eyes! Under the passenger seat maybe? Nice to see the photos back though.
Believe it or not the Jaguar XK is about as good on fuel when equipped with well set up Webers as it is on the XJ6 S3 with fuel injection.
"You're about as likely to come across a fully functioning old Jag, as you are a taxicab that smells agreeable." - James May
Mar 20, 2014 18:53:17 GMT
That is good to know Rich. Another job now done is the fuel level sender unit. This had to be ordered from Speedy Cables but they needed to know the spec of the particular fuel gauge - and I could only find the resistance value across the gauge when empty - so they supplied what might do the job..... I rigged up a circuit and found that the gauge read in reverse when I moved the float arm! Then I realised that the float arm resistor unit could be put on upside down and with a bit of fiddling it now gives the full gauge reading for the full movement of the float. After that I had to carefully drill and tap the 5 holes to mount the unit in the tank - making sure no bits went inside.
Last Edit: Mar 20, 2014 18:53:57 GMT by flyingphil
Apr 22, 2014 16:25:14 GMT
More jobs done as I have now plumbed in the vacuum pipes for the twin servos and a short tube to connect the heater pipes together - so the back of the engine has got a bit crowded! Another job has been to shorten the gearstick - it was catching on the bottom edge of the dashboard. I have cut off the bottom threaded section, then drilled and tapped up the gearstick.
Apr 28, 2014 20:24:21 GMT
Having sat in the car (And yes I went Brrrmmmmm Brrrrmmmmm!) I found that the dashboard layout was not easy to read so I have moved the other large gauge from the far left to the right of the steering column and moved the small fuel gauge to the bottom right hand corner. I think this looks a lot better and also has the advantage of getting the two indicator warning lamps back in the correct orientation as they are part of the rev counter and speedometer displays. The proper Walnut dashboard is still to be cut and so it will be to this layout.
I have been shopping at Europa Spares - what an Aladdins cave!! I also tried a Cobra windscreen on the Ronart - but it is too wide. Then I tried a Sprite windscreen - and that is too wide so the owner has said he will go with the aeroscreens for the time being.
Following the saga of the gearbox/bell housing/ starter motor, when I finally tried to spin it on the starter, there was a horrible noise from the ring gear and pinion. I checked that all was in the right place and tight, still the same, I put a bit of oil on the ring gear, still the same. I took the starter off and checked it and the tooth engagement pattern - nothing obviously wrong - checked that an auto starter is the same as a manual starter - reassembled and still the same noise so I wondered if it was due to the new ring gear and old pinion. Other people have also checked it and there has been no solution. I contacted the engine builder and showed him the starter and pictures of the bell housing and I now have 3 more Jaguar staters to try - all different and two different pinions teeth count..... On a brighter note the car has now moved to the paint shop - it towed very nicely!
May 21, 2014 16:59:06 GMT
It is now sprayed and I can start the final assembly.
Last Edit: May 21, 2014 17:00:27 GMT by flyingphil
sonus
May 21, 2014 17:38:45 GMT
That looks really good! Is that Connaught BRG?
Frankenhealey
Club RR Member Number: 15
Please tell me he's going to change the steering wheel?
May 22, 2014 16:12:26 GMT
That looks really good! Is that Connaught BRG? Hi Sonus - it is a Lotus BRG And "Yes" Ian, we do have a much nicer three spoke steering wheel to put on.
May 28, 2014 22:40:21 GMT
We now have the new steering wheel and a heater unit so I have started to put it together.
Last Edit: May 28, 2014 22:41:39 GMT by flyingphil
Phil - Are you taking this through the IVA?
Phil - Are you taking this through the IVA? That is the intention - although there are some aspects that need to be made "IVA compliant" it is a routine that the Ronart makers know well.
Frankenhealey
We now have the new steering wheel a That's better but these days I woodn't (pun intended give one of those houseroom. In a galaxy far far away in another aeon I was doing recoveries to assist the finances of building hot Minis. That also meant accident pickups . One I went to had the remains of a wooden wheel with a good portion of the driver's palms stuck to the jagged splinters. My BJ8 came with one but I was so unhappy with the potential that it got swapped out for a IMHO much safer leather rim wheel.
May 30, 2014 18:49:35 GMT
Yes Ian - I know about the concerns re wooden rims - on my cars I have leather too - but the owner wants that look...I did check the rim and it is in fact a riveted laminate and so less likely to splinter? Also I now have a quiet starter motor ring gear engagement! Of the four starter motors, one had 10 teeth on the pinion (all the others had 9) and hence very slightly narrower teeth at the root - so I put that on and it now all whirs round very nicely. It is an inertia type so I need to put a starter solenoid in the feed wire - touching terminals is not a long term solution!
A bit more done and so a new picture - but "Spot the differences".......No prizes - just eyestrain
I think you need to take a look in the mirror before posting the same picture again!
Is the heater original Jaguar? Looks quite compact.
Click picture for more
Yep Mirrors and the heater is plumbed in. The heater is from Europa Spares. Yesterday was Goodie Time!
Jun 27, 2014 17:55:56 GMT
Exhaust is now fitted - which proved to be yet another saga but a good job has been done by Tube Engineering in Market Rasen. I have also done some work on the inside now that the seats have been leather trimmed (Thanks to Tony Baldassarre in Bedford)
Last Edit: Jun 27, 2014 18:02:11 GMT by flyingphil
