May 20, 2013 19:49:20 GMT
Update Finished the electrics all the lights work so fitted the rear lights and dash and steering wheel brakes done on one side the drivers side upgraded to 239 vented discs and calipers G40 spec. New cv boot also fitted also removed the outer cv and gave it a good clean and new grease have also ordered two new track control arms will come next week. other side still to do big difference!
Retro Concepts LTD Automotive Fabrication, Customization & Conversions.
Fitted some wheels the original steels hit the calipers and had curse word tyres so had some crappy alloys with good tread fitted for now. still need to fix the wings but might just bodge it for now so it looks good for mot until I can get some new panels. FUN
Did this come from Bournemouth??
Did this come from Bournemouth?? Yes it did a guy called Paul also owns a mk1 caddy!
Jun 20, 2013 13:10:27 GMT
Did this come from Bournemouth?? Yes it did a guy called Paul also owns a mk1 caddy! Thought I recognised it! Will be interested to see how it turns out.
Jun 24, 2013 19:52:25 GMT
Well its time to start the body repairs so first on my list is the wings and front panel started with the wings done plenty of welding to the under body of cars but never the car body also had to get the right shape of the wing front corners mine was shot and it was hard to get an idea of the shape so with lots of time checking pictures on the net to get an idea of the shape then made a card board template and ended up with this. and then used the mk1 golf wings that i got to use for metal then with only a hammer my hands and a grinder turned it in to this was very happy for my first try and then test fitted needs some work but will start the other wing and get it to the same point. and made the repair panel placed on other wing and thats as fare as i got to now.
Jun 25, 2013 17:04:53 GMT
Got the other side started did more to this side than the other again happy with the results first the Front panel then test fit the wing with the new repair and then put the wing back in the shed and sprayed a little primer to protect over night will get the other side to the same point tomorrow
Jun 26, 2013 23:52:05 GMT
Jul 18, 2013 15:20:32 GMT
Jul 19, 2013 15:41:26 GMT
Jul 19, 2013 16:28:30 GMT
Make sure to cut the arch a bit so as to allow the fuel filler door to be opened! (Or cut the fuel filler door)
Jul 19, 2013 20:00:12 GMT
Where did you get the arches?
I would be rich if i had not spent so much money on Cars and fast women...oh, i did waste some of it as well!
That oversill was the biggest waste!!!
79cord
Glad to see the progress, the new arches do look nice. Shame the sills were such a mess.
Jul 20, 2013 12:12:02 GMT
this is awesome personally the wheels are too big and the wrong style for the car...but that's just my opinion...as long as its something you like
Jul 23, 2013 16:32:24 GMT
Small update Finished the drivers sill today thats all the big rust repairs finished and small patches left:) I have done the drivers floor pan but kinda bodged it for now until I'm on the road and will cut a floor pan from a scrapper and do a proper fix To do list. in no order! 1. Finnish welding the inner and outer skin on the rear drivers arch and then start the same to passenger side so i can get the arches fitted. 2. fit rear and front arches 3. fit new brake pads and rear hoses and then bleed brakes. 4. fit new tca's 5. refit fuel tank 6. Finish exhaust 7. fit rear 6n collies i have spare. 8. make custom temp coilovers for the front with spares i have. 7. finishing touches grind the welds and add a little filler and get all the body panels aligned. My aim is to get all this done ready for retro rides gathering and if i have time maybe some more
Jul 25, 2013 10:10:52 GMT
what fascinates me the most is the amount of work that cill cover must have taken, and yet still be so horrific. must have been more than the sum effort to cut out the original and replace it properly?
Jul 26, 2013 22:54:50 GMT
derbys coming along really well,yes get it done for the gathering come on the mk1polo/derby stand if you like??
Jul 28, 2013 22:51:56 GMT
Thanks lukeherbert and let me know more by pm Finished today welding the rear arch ready for the bolt on arches and after a little paint. shaped the arches better to fit the derby shape Rear rear Rear front looking good Now just need to start the passenger rear arch should be easier now i know what to do and the last of the major welding work Ordered some brake fluid and new brake pads for the front to finish the braking system.
