retrojoe
Life is to short to drive boring cars.
Mar 29, 2013 17:24:51 GMT
Hi guys, Can anyone tell me what carburetors these are? the guy who sold it to me did say but i forgot:( and if anyone knows where to find information and parts? also what do people think about running without airfilters? ive never agreed with it personally although i know people do it. so whats the best way to attach a filter aswell? Thanks for the help. Joe:)
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Mar 29, 2013 18:00:33 GMT
They don't look like Webers to me. I have a sneaky suspicion they may be Solex, but I dunno what model
Are they attached to a Fiat twin cam? A chap I know had an Fiat twink with a pair of them on it
Last Edit: Mar 29, 2013 18:01:32 GMT by MrSpeedy
Kieran
Mar 29, 2013 18:08:11 GMT
Dellorto DHLA 40 or 45.
Should be cast into them somewhere.
You can get lots of filters for them of different depths. The filter backing plate goes behind the inlet ram pipes (trumpets).
Last Edit: Mar 29, 2013 18:09:30 GMT by Kieran
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
retrojoe
Mar 29, 2013 18:10:36 GMT
yep, it certainly is a fiat twin cam:) with 200bhp apparently!? not that i know much about these things
retrojoe
Mar 29, 2013 18:48:57 GMT
Thanks kieran! Thats brilliant! Now I can start tinkering;)
what are these carbs?stealthstylz
@stealthstylz
Club Retro Rides Member 174
It would be a seriously worked Fiat Twin Cam to hit 200bhp. Awesome engines though.
As said Dellorto DHLA's if you look at the far barrel next to the distributor cap ( the orange thing with black plug leads coming out ) it will have a cast ledge with DHLA 40 H or DHLA 40 F or some thing like that then you can google whatever it says and a hole world of info will open up to you.
They more difficult to set up than weber's but far superior if you can master them..
retrojoe
wonderfull! thanks guys. also does anyone have any good ideas on how to link the chokes together? was going to drill a hole and run a cable between them but i think the throttle linkage will get in the way so any other ideas?
Dez
Club RR Member Number: 34
what are these carbs?Dez
@dez
Club Retro Rides Member 34
Mar 30, 2013 13:42:03 GMT
It would be a seriously worked Fiat Twin Cam to hit 200bhp. Awesome engines though. what matt says. it wont be 200hp. thats nigh on impossible on a N/A twink. realistically, if it runs on 'normal' petrol and is street drivable, even a 2L with better cams and 40s will only be around 140-145hp.
Mar 30, 2013 14:10:42 GMT
Forget the chokes just leave them disconnected they flow far too much fuel in and are unreliable just give the throttle a quick blip before you fire it up and balance the throttle until its warm it wont take long..
retrojoe
yer, i see where your coming from and i started it up today and it idled fine, but it did take a little while to get it going. there is already a choke cable there its just not attached so i would like to have it connected then i always have the option of using it or not.
is there some sort of bracket that can be bought or made to link the two?
