That's some terrific stump pulling you've done there. I dealt with three large stumps in my garden by hand 'cos I couldn't get a vehicle near enough. It's amazing how well a handful of puny looking roots can hold on to the earth! I'll second Google (now Trimble) SketchUp. The learning curve is gentle and instant results can be had. You can even export views as PDF files to use as printed out plans with dimensions. Top software. I've bought the full version that gives extra export options for work as I often produce 3D drawings. Hallo Wagoneer mate !!! Trust you are well.
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
UPDATE! The garage to be has a new name. Overdrives Skunkworks: www.facebook.com/OverdrivesSkunkworksI'm starting to develop the plan for this garage and how its going to be used. Some interesting ideas forming. In the meantime, I've been plodding away with the ground works.... The massive pile of waste wood has now been reduced to this: Leaving me with a reasonaby clear site and enough wood to survive an ice age. Trusty Vitara is soon to be gone, and replaced with something a bit more "skunkworksy" Watch this space...
ToolsnTrack
Homebrew Raconteur
New Updates! The contractor for the building has been in touch, "The Garage" is now ready for delivery! Great news, except i still have NOTHING to build it on. Could be a busy few weeks! :S
Cant believe the ineptitude of builders up this neck of the woods....
ToolsnTrack
Homebrew Raconteur
All wood now completely segregated, and all waste disposed of (with matches). Contractor should be good to go with base laying in 4 weeks....
Making some good progress Are you going block built garage, wood, or something else?
1965 Mk1 Mini 1989 Porsche 911 3.2 Carrera Sport 2004 Audi A2 TDi 2007 Lotus Exige S 2011 Mini Cooper SD
ToolsnTrack
Homebrew Raconteur
It's prefab concrete.
ToolsnTrack
Homebrew Raconteur
Apr 25, 2013 13:50:45 GMT
In light of recent developments, some budget shuffling has been done. Project 7up is suspended this month, and the budget has been spent on 2.5mm power cable (100m), 25m of conduit for burying, and a consumer unit. Fingers crossed there's some left over for lights....
Apr 25, 2013 14:36:05 GMT
WOW...! BRILLIANT...! Enough said...
***GARAGE CURRENTLY EMPTY***
Apr 25, 2013 19:22:07 GMT
Good to see this progressing!
Just a quick point though - are you planning on using 2.5mm as your feed cable? It's not really going to give you much scope , especially if you are putting in a 25m run of it to the garage.
I may have got the wrong end of the stick, but even just a 16A supply over this distance would be up into 4mm cable (with a 5% voltage drop), if you're looking at running some heavy stuff such as a welder and the like, a 30A supply would be a sensible idea - this would put you up into 6mm cable. Also, if you're burying cables, they really should be steel armoured (SWA). Like I said - I may have read it through wrong.
Always good to be over-spec on cables, than under though!
As you were..... Joe
ToolsnTrack
Homebrew Raconteur
Apr 26, 2013 18:09:46 GMT
Yea, the 2.5 will be for socket and light power *in* the garage.
Apr 27, 2013 12:38:47 GMT
Excellent! Hoped that was the case! ....have I told you about this great way to suck eggs...? Joe
ToolsnTrack
Homebrew Raconteur
Apr 27, 2013 16:20:27 GMT
Not at all, all advice welcomed!
ToolsnTrack
Homebrew Raconteur
Last of the stray wood burnt last night. Left me with a nice open space. Thursday is now solid for the concrete laying!!
ToolsnTrack
Homebrew Raconteur
It begins. The crew arrived early doors and started chiselling out the base... and then edging... Once low enough, the first layer of hardcore went in: ...with Mrs Overdrive featured to provide scale. Lastly, this was pounded in... ...and work stopped for the night. Second layer of hardcore to arrive tomorrow, then the edging will go down for the concrete pour. This might not happen tomorrow, weather is to be horrific. Might push it out till Monday....
Granadaman72
I likes Granada's, Cortina's, Sierra's, Viva's, Marina's....................
Great stuff, so jealous, wish i had somewhere to build a garage
ToolsnTrack
Homebrew Raconteur
More progress! Second layer f hardcore now in, and flattened. Frame for the concrete lay is now in place too. Fingers crossed the weather holds off enough to get a good lay today! (oo er)
Are you dropping mesh in??
ToolsnTrack
Homebrew Raconteur
Yep. Just barely visible on the grass of the first pic is the rebar.
Tilcon do a concrete mix just for floors its called fibrous it has strands of nylon fibre mixed in and combined with well placed mesh can half the depth of fill.
Its worth a look.
ToolsnTrack
Homebrew Raconteur
Probably not, concrete was to be laid this morning!
