1980 Vauxhall Cavalier MK1 1970 Mobyleete 40T custom 1978 Mobylette 50V 1965 Moulton Standard 1979 Raleigh Grifter custom 1980 Raleigh Grifter 1982 Raleigh Grifter BMX custom 1982 Raleigh Bomber 1987 Strida
Last Edit: Feb 4, 2013 10:16:38 GMT by cavboy80
fred
WTF has happened to all the Vennies?
Ooooh thats a minty minter loving that car sire oooohhh (had to say that again)
'79 Cossie ran Cortina - Sold
2000 Fozzer 2.0 turbo snow beast
'85 Opel Manta GSI - Sold
03 A class Mercedes
Looking for a FD Ventora - Anyone?
düdo
wide as house
Yes, good work there. I really like it stock and simple : very nostalgic. I had similar chequered cloth in my '81 Chevanne
MK2VR6
Mk2 Golf GTi 90 Spec
Good lord, that's gotta be one of the best 2 door mk1's left. Love the photo of it as a wedding car in its early years; sterling work on giving her the fine tlc she clearly deserves. Approved!
energy
shes beautiful!!iv an orange 77 1600l with 52k on the clock and a yellow 80 1600gl with 54k on the clock.always wanted a red one but can bring myself to waste the originality of them.
unitybonez
Blowing Pintos
I love those, like a chevette bigger brother. Needs mega lows and silly fat wheels thou Good work keepin it mint!
Sent from my ouiji board.
Apr 20, 2013 18:59:30 GMT
33 years have taken its toll on the original dealer sticker. Today though I noticed that it had really let go, cellotape is now holding it together. Can anyone out here help me with someone who can replicate it. I really want this on here as it makes the car. HELP!!!
Last Edit: Apr 20, 2013 19:06:22 GMT by cavboy80
Apr 20, 2013 19:04:08 GMT
tbh a decent vinyl signwriter could replicate that
It's good to see an update on this real gem of a car... It is looking as good as ever and looks like it will continue to do so whilst it's in your care...!!! Brilliant...!
***GARAGE CURRENTLY EMPTY***
Oct 26, 2014 22:29:03 GMT
It's been a while since i last updated this, some minor work and servicing has occurred but recently a far bigger job has reared its head. MK1 Cavaliers and its Manta/ Ascona have a common built in rot spot This is how the areas looked The outer skin was removed to expose the solid but scaley inner reinforced section. Note the crude construction four of these repair panels were bought so as to triple skin the area and ensure the area is as strong as new. Also due to a blocked drain hole the rear of the sills had become slightly holes, the blockage was due to over-enthusisatic rustproofing slight filling and all invisible As the engine and gearbox had to come out to do the chassis areas (the rear of the engine bed had to be dropped down) i took this as a chance to really detail both as well as the front suspension Engine bay BEFORE Due to a leaking rear oil seal the box was filthy, this was degreased and painted Gearbox mount Lower bellhousing plate Whilst doing the box it was noticed that there was too much 'slop' in the selector shaft. A mate of mine made two 'sleeves' to remove it but still give a little float. The selection is now a lot slicker Attention then turned to the engine, yes, i had painted the engine when i first bought it in 2002 but now out of the car i had a lot more access. And i was going to make the use of it. This was stripped down The sump came off for painting block head Rocker cover Rad engine inspection plates starter manifold servo Engine built up The chassis work was done and the engine bay and suspension came in for some work Much better than the 'before' pictures The stabiliser links and rack gaiters were replaced whilst access was good, then today the time came to reinstate the engine and box. Matt Of The Vivas came to help Comrade Pau appeared to help with dropping the unit in. l new clutch, well, why not With some little snags it went in and runs a treat, still got some small jobs to do. But the worst is done Action shot Whilst doing this i replaced the gearbox rear oil seal, speed drive, brake fluid reservoir cap, steering rack gaiters, Stabilser links. It's been a long slog but it was needed to be done. i'm so chuffed how it turned out.
This must be one of the cleanest mk1s kicking about, and being a 2 door makes it even better! Nice job on the engine bay, I can really appreciate it as a detail freak
That is such a gorgeous car...! Just beautiful...
moomin
Oct 27, 2014 10:20:03 GMT
Awesome! Such a good looking car.
I had one of these about 7 years ago, used it for the daily commute. Lovely to drive, loved the enormous feel of interior.
Happily have enough one any day. Good work sir!
@toxicknobs
Oct 27, 2014 16:58:22 GMT
Today i detailed the engine and polished the engine bays paintwork I painted bolts and touched in the very few small chips that appeared from putting the engine in yesterday. This side has far more access than the the other. When i cleaned down the engine originally i noticed on both engiine mounts that yellow paint was over the bolts and washers, I redid these so to keep the originality, was this an anti tamper measure from the factory or part of their QC? Any ideas?
Oct 27, 2014 17:07:36 GMT
Lovely Cavalier! She looks mint.
In my experience they used to paint nuts like that on the factory line to show that they had been torqued up to tension. Especially important load bearing parts like the engine mounts.
Nowadays it's done on a rig by a robot so not as much human error.
Last Edit: Oct 27, 2014 17:17:19 GMT by blacksaff
Twitter @w0rd5w0rth
1957 Ford Prefect 1965 Austin 1100 4 door 1968 Fiat 500L 1969 Ford Escort Super 1971 Vauxhall Viscount 1974 MGB GT 1978 Vauxhall Cavalier GL 1981 Ford Capri GL 1982 Ford Cortina Crusader 1985 Vauxhall Cavalier L 1987 Austin Maestro City 500 1987 Ford Fiesta 1.1L 1988 Volvo 240GL 1989 Ford Sierra Cosworth 1991 Fiat 126 BIS 1993 BMW 740i 1997 BMW M3 Evo 1998 Ford Transit Beavertail 2002 MINI Cooper S
Oct 27, 2014 18:10:50 GMT
Thanks for explaining the reason Blacksaff, likewise for your MK1.
Oct 27, 2014 23:45:11 GMT
Your doing an excellent job there Jason, It's as good as new now! Can anyone out here help me with someone who can replicate it. I really want this on here as it makes the car. HELP!!! I don't know if your still after one of these but contact DMB, they should be able to make you up a new sticker if you give them the measurements and some close up photos, they done one for me for my Merc. www.dmb.uk.com/
Oct 28, 2014 17:53:04 GMT
Thanks for the 'heads up' Trigg, yeah i still need the rear sticker redoing in fact the poor thing has got worse since this picture was taken. I'll make contact with them.
I contacted DMB after Triggs recommendation and less than a week i have this. Now that looks so much fresher it's rolled back the years. It's amazing what a little detail like this can do to a cars appearance Thanks Trigger.
