I am selling my Lada Riva Estate 1.5E, it's a 1995 on a M reg,
Tax no
M.O.T May 2013
f,s,h
8,600 miles
I have a thread on it which should fill you in on the details of some of the work I have done to it since I took ownership, I have done more than is in the thread though,
retrorides.proboards.com/index.cgi?board=readersrides&action=display&thread=116277
the car is complete and ready to go other than the tax needing put on it, it is on SORN, never be welded, parts that I have replaced with new parts are .....
new master brake cylinder and brakes bled
new gearstick fitting kit
new fuel tank sender unit
new half shaft seals
new complete lock set
gearbox oil
axel oil
engine oil
oil filter
air filter
new radiator
one new Toyo proxe 175/60/13
three are part worn
new bespoke set of GAZ shocks
The door rub strip's have been removed now to give it a cleaner look down the side's.
replaceing the halfshaft seals
replaceing the radiator
I had it up on the ramp to change the oils, if you look at the exhaust you will see where I cut and turned it to give a liitle more clearance,
the sill's
new master cylinder
up at santa pod
the car is on sorn and locked up in a garage so the milage wont be changing, it needs tax and a new owner, I have all the owners books etc plus the only M.O.T cert this has ever had, read thread.
lot's of bills for parts that I have bought plus a spare set of wheels for the winter, it has the tool kit in the boot and I have another front antiroll bar which will need fitting, it's a good mod that they use back East, the gaz shocks have done about 2000 miles, with the toyo proxes, the Gaz shocks and the shorter springs it goes round the bends very well, it upsets the modern car drivers quite a bit, he car body is solid as a rock,
the car is a hoot to own, people come and to talk to you when ever they see it, will consider a swap with a Mini or something ford, escort mk4 would fit the bill.
looking for £1200
the car is in Staines middlesex
I can arrange for the car to be delivered if needs be
contact me on 07738398938
cheers .
Tax no
M.O.T May 2013
f,s,h
8,600 miles
gearbox oil
axel oil
engine oil
oil filter
air filter
new radiator
three are part worn
the sill's
new master cylinder
up at santa pod
looking for £1200
cheers .
