ruffgeezer
Attracts french tat.
Oct 13, 2012 21:36:42 GMT
Onto today's toolage; These are marked Arnold & Sons, and punch out a club shape in use, but I cannot find anything about the company or the product on the web, so does anyone of the 'wibblepoo know what the intended use of these was? Well after the trickle of information suggesting that these were a veterinary implement, I took them to work and left them behind the till, the garage is situated as such that we get a lot of farmers through the door, including Lincolnshire's Farmer Wink: Who kindly identified them as a tool for clipping animal's ears so as to mark ownership... Lovely.
ruffgeezer
Oct 21, 2012 18:52:16 GMT
Right another weekend saw out the sorting of the tools, here is box one of the 3 I looked at today: Quite small this one by current standards, here is all is laid out, does anyone want to suggest what the 3 pins are on the left next to the packet of sockets? Not a clue what this is, my initial thoughts were a tyre valve tool, but it has a slot one side for the full length of the blade? Specialist Bedford/Vauxhall tool, no idea what for mind:
Oct 21, 2012 21:20:22 GMT
They are generally known as " obstruction spanners ". You can actually buy them with all sorts of weird & wonderful angles. Most people , me included, just used to make our own. You just need to have a spanner that is long enough to allow you to heat it up & form it in to the shape/angle you want , whilst still leaving enough to enable leverage. That's just been made for Vauxhall to the spec they required .
Todos con Lorca
Oct 21, 2012 21:27:50 GMT
Todos con Lorca
Oct 22, 2012 13:04:16 GMT
Hi, they have a number of names (locking pins, Detent pin, ball lock pin, quick release pin) They can't fall out because of the 2 little balls at the end, but when you pull the pin by the ring at the top it releases the balls to retract and the pin slide out.
Colin
ruffgeezer
Oct 22, 2012 18:13:14 GMT
Thanks guys,
Colin, what would one use a detent pin for?
Thanks guys, Colin, what would one use a detent pin for? Hi, it will be used for a secure fixing, not high load, but quick release. I work at the airport and when an aircraft is pushed back off of stand the ground crew put one of these pins, which has a ribbon of fabric attached, into the nose gear which disconnects the steering from the pilot. when the aircraft is out on the taxiway the ground crew disconnect the tug, pull the pin, retreat from the area whilst showing the pilot the pin and ribbon to show he has control again. Not perhaps a good example but on a car a comparison would be an 'R' clip, like as used on a bonnet pin or a brake pad pin. Colin
ruffgeezer
Oct 23, 2012 21:32:28 GMT
Very interesting to know, I wonder how they came to be in a box of tools, they don't look that well used!
ruffgeezer
Oct 23, 2012 21:37:42 GMT
Next box's contents: Some sort of injector seat cutter perhaps? There are 3 sets of these tiny spanners, not sure what their intended use was though... Err... no clue... The other end on this takes a 1/4 drive adapter, this end is slightly bigger than 1/4 drive, again, I'm not sure of the intended use: Nearly new copper/hide hammer, bringing the hammer total to just shy of 40 by my estimations: I had no idea what the hell this was, but I'm told it is an oil stone for knife sharpening! Cheese knife? As always, there is more to come, including the result of putting the ear marking pliers on ebay!
Oct 23, 2012 23:31:39 GMT
Hi, right me again. The seat cutter is not for injectors but for taps, kitchen bathroom etc. the spanner sets are for the car, as well as the spanners there is a screwdriver one end and a feeler gauge the other, either 15 thou for points or 25 thou for the plugs. the right angle bar is for a socket one end and the 1/4 sq socket the other is an adjuster for the brake shoes. The oil stone is as you say for sharpening knives, wood chisels and plane blades.
Colin
Oct 24, 2012 17:23:35 GMT
Agree with all the above + that is a fish knife, minus its handle.
Todos con Lorca
Midas
Club RR Member Number: 14
Oct 24, 2012 17:36:46 GMT
Thanks guys, Colin, what would one use a detent pin for? They are also known as pip pins, not cheap to buy as you'll see in the link below. As already mentioned they are used in aerospace as a secure quickly removable fixing, the seats on our Air Ambulances are held to the tracking with them allowing fast adjustment and reversal of the seats. www.demon-tweeks.co.uk/motorsport/bonnet-pins-fasteners/demon-tweeks-pip-pin-2
Last Edit: Oct 24, 2012 17:37:22 GMT by Midas
ruffgeezer
Oct 27, 2012 13:02:10 GMT
Interesting thankyou! Perhaps I'll bung those on ebay as I doubt I'll ever have a use for them! Onto the bucket 'o' spanners then, I had anticipated this as being the least interesting of the haul, fully expecting a range of imperial stuff that was of little use, so how'd I do? Some odd pliers: A...er....uhm... it looks like a wrench jaw, but again I'm probably wrong. Another bunch of tiny spanners: My best friend's dad was an engineer through the 70s and 80s, he always mentions this brand of spanners: So here they all are laid out, all imperial and a variety of shapes and sizes: There were a few manufacturer's tools in the collection though, weird to think this was probably normal back in the day: History in tool form: Now this kit is a neat little thing, and most surprisingly, it is complete, although not much use on anything that is done up tight I'll bet: And that is all... Nope! Under the layer of imperial stuff, there was a treasure trove of metric gear, a lot of which is Britool (you know, when they weren't sub-letting to china for stuff made out of old sweetie wrappers and Tesco's tin foil): The set of offset spanners was probably worth the outlay on it's own, they have been put straight into my 'A' tools at work. If anyone does see anything here they might want or need, feel free to pm me, I'd love to find uses for as much as possible!
Oct 27, 2012 16:33:31 GMT
Some cool stuff there.
Next box's contents: Some sort of injector seat cutter perhaps? There are 3 sets of these tiny spanners, not sure what their intended use was though... Err... no clue... The other end on this takes a 1/4 drive adapter, this end is slightly bigger than 1/4 drive, again, I'm not sure of the intended use: Nearly new copper/hide hammer, bringing the hammer total to just shy of 40 by my estimations: I had no idea what the hell this was, but I'm told it is an oil stone for knife sharpening! Cheese knife? As always, there is more to come, including the result of putting the ear marking pliers on ebay! Seems to have a set of hallmarks, so might be worth a polish to see if it's silver. Sent from my HTC Desire C using proboards
Toyota mk3 supra. retro goodness.
Dez
Club RR Member Number: 34
Oct 28, 2012 21:31:14 GMT
the optimus packaged 'not a clue' item will be a part for an optimus paraffin stove.
Dez
Oct 28, 2012 21:39:07 GMT
oh and the AAEP markings on the knife are not a hallmark, they mean Argentium Argentine Electro Plate, another name for EPNS.
ruffgeezer
Oct 28, 2012 21:55:20 GMT
That explains the slightly bronzish tarnished finish then!
In the optimus packet, I have what looks like a pair of cheap spoon handles, no idea what use they'd be!
ruffgeezer
Ok a few more oddities from the collection: An un-sized Britool spanner with a concaved end, is this for bashing the ends on rivets perhaps? I thought these might be for cutting keys, there are numbers on the dials: I've now a good collection of A/F and Whitworth spanners now:
