quackshot
...friggin' cars...
Hey folks, looking for some advice.
I recently got me a 1990 (3rd gen) Toyota Townace and it needs a good whack with the stick.
I had a look under the front and there are no springs just shocks. I did some googling and it talks of a torsion bar (which makes me think of beetles) but this is double wishbone on the front.
Also The springs will want changing on the back, I'd prefer not to chop them as I don't want to be a total tight ass!
Anyone have any experience lowering any of the toyota 'ace' family? All advice welcome!
Dez
Club RR Member Number: 34
Lowering a Toyota TownaceDez
@dez
Club Retro Rides Member 34
its similar to a mazda b2000 mate, you have to release the tension on the torsions, and re index them to get the drop. i think they slot into the lower wishbones on these. its kinda like doing a type 3, but the torsion bars run lengthways along the chassis rather than side to side.
Some of the Nissans just adjust down , might be the same, what wheels you running then?
quackshot
...friggin' cars...
The front adjusts down, the rear needs alternative springs. Was hoping to not just cut em.
quackshot
...friggin' cars...
Jul 22, 2012 16:27:09 GMT
Just to point out to anyone else, the torsion bars for the front (as dez said) run along the chassis rails and the adjustment is about halfway down the van. The drivers said is in-between the battery and fuel tank, passenger side next to exhaust. Requires a 22mm socket. Having a deep socket and an impact gun to remove the locking nut will save you a lot of swearing!
Jul 31, 2012 15:56:33 GMT
hi just been put onto this thread as i thinking of buying a lite-ace BUT only if it can hit with a lowering stick ;D don't want to buy it and then find out it won't lower so i get the front bit on this thread about torsion bars as i had that done before to a vw t4 velle on the front plus shorter shocks and springs on rear had a look on ebay and only lowering blocks come up to lower the rear any more ideas quick as i need to decide over the next day or two before committing to buy ;D bob
eddbmxdude
Yeah, its a turbo!
Sept 15, 2019 22:50:43 GMT
Apologies for digging up an ancient thread but I've got a Townace and I want to lower it. Front is easy, it'll adjust down on the torsion bars.
Rear is shocks and springs. I really don't want to cut the springs. Anyone know if there are any other cars that have the same size springs? I'm trying to find ones of a similar size from a more readily available car so I can find some lowering springs.
Finding parts for this Townace has been a nightmare.
Old skool cool!
Signature image maximum height: 80 pixels
