Hi gang,
Any idea what these are worth roughly?
Centra turbos, 14x6J, 4x108 PCD, ET30
In OK condition, there's moisture under the lacquer in places so could do with a bit of a polish to look perfick. Only one has any real kerbing and it's not too bad. Got all the centre caps and the bolts to hold them on (bit knackered)
The reflection of the flash has made the corrosion look much worse than it really is.
So wodja reckon they're worth a) as they are and b) with a bit of a tidy up?
Cheers
Cheers
