Hi All,
One of the guys where I work is selling his Disco.
www.ebay.co.uk/itm/Land-Rover-Discovery-modified-off-road-ready-use-300tdi-6-seater-/160762302795?pt=Automobiles_UK&hash=item256e2e114b
More pics on the ebay page
Land Rover Discovery, modified, off road, ready to use 300tdi 6 seater
3 door very modified and very capable land rover, used on and off road, new remote central locking, last serviced Nov 2011, all filters and engine oil. Timing belt changed at 195812 miles Aug 2010, loads of tread on tyres, both front swivel bearing recently replaced. New heavy duty battery and glow plugs fitted last winter. New boot floor fitted professionally two years ago. EGR valve professionally removed. Land rover rubber matting fitted throughout. Thousands spent on quality parts and modifications. Despite high mileage it starts and runs fine with a little smoke on overrun, rarely have to top up water or oils. One month MOT it will probably require a small amount of welding and the hand brake adjusted for next MOT. Tax until 31/10/2012
Extras;
Winch bumper
Roof bar with 4 spot lamps connected and working (glass damaged on one lamp, easily replaced)
4 inch lift (2”springs and 2” spacers)
Extended shocks all round
Front radius correction arms (QT)
Rear dislocation cones
Heavy duty steering guards
Heavy duty front diff guard
Chequer plate (sides)
Discovery rubber matting
Deep dish Weller wheels X4 spare is modular all have good tyres 265/75 R 16 (mud tyres)
Extended wheel arches
Safari snorkel (connected and working)
Axles and gearbox breathers
Clear front indicators
The following items WILL BE REMOVED for my next project;
Britpart 1200 Winch “needs mending anyway”.
CB Radio with 4 foot whip
Bad points;
A few battle scars and scratches (from green laneing)
Chassis has been welded in the past and will need small amount of welding for next MOT
American style rear light clusters (indicators flash red), but normal in the bumpers
Wheels need balancing (dose not bother me as it has been used as a toy)
Hand brake needs adjusting
2nd gear crunch (usual disco problem, has not got any worse in the 2 years I’ve been using it)
Rev counter doe's what it feels like
Interior a little scruffy
Twin sunroof (rear taped up, both currently not leaking).
Extras;
Winch bumper
Bad points;
