Jan 28, 2012 14:27:06 GMT
Hi all, new around here so I thought post up some pics of my cars. This is my merc w124, she started life as a standard 300e auto, but I have been modifying her for the past 4 years. I have converted her from an auto to a getrag manual, changed the engine from a 3.0 12v to a 3.6 24v, fitted bigger brakes, fitted sportline suspension, a bodykit, and electric leather seats. Future plans may include forced induction.
Last Edit: Jan 8, 2014 7:11:45 GMT by carat 3.6
Jan 28, 2012 15:30:10 GMT
Nice car dude and welcome.. nice to see m104 with a stick behind really brings out the best in the lump. . you running a funky diff or just stock ??
300ce lowrider c220 track car c280 youngtimer S320 ...vip no 4 S430 .. 2 x slk 230 500se , E36 amg E 430 E55 amg Ml 320 C43 amg
Jan 28, 2012 15:40:34 GMT
Nice car dude and welcome.. nice to see m104 with a stick behind really brings out the best in the lump. . you running a funky diff or just stock ?? Thanks. It's got the stock diff at the moment, but I'd like to fit the lsd from the cossie 190.
Ray Singh
More German exotica in my garage now
Jan 28, 2012 16:16:52 GMT
Really nice car - I like it very much. What plans have you/ Turbocharging or supercharging?
Jan 28, 2012 16:34:28 GMT
Really nice car - I like it very much. What plans have you/ Turbocharging or supercharging? Thanks. I've got a eaton m62 from one of my other projects that I thought of fitting to it, along with the charge cooler from a jag xjr6. I've also got a monstrous holset turbo from a cummins bus engine that I have been mocking up under the bonnet.
Jan 28, 2012 16:34:36 GMT
I love the car mate?? Getrag straight swap?? Looking to fit one to my w202
Jan 28, 2012 16:49:18 GMT
I love the car mate?? Getrag straight swap?? Looking to fit one to my w202 The getrag bolts up no problem, but you need the early single mass flywheel. The gearbox crossmember needed altering to fit, and the propshaft had to be swaped for a longer one.
Sinky
Run Baby Run......Please!
Jan 28, 2012 17:32:10 GMT
Hola.Nice Car. We meet again. MB club
Last Edit: Jan 28, 2012 17:36:15 GMT by Sinky
2001 Volvo XC70 wagon
2003 Piaggio X9 Evo
Jan 28, 2012 17:43:38 GMT
Hola.Nice Car. We meet again. MB club I think we must have a good taste in forums. And cars by the look of it, I didnt know you had a granada.
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Jan 28, 2012 19:42:44 GMT
Looking goooood. Always nice to see the Benz mafia growing ;-) Similar styling to my intentions for my 300ce.
So today I fitted my new steering wheel, much better than the old one.
So time for an update on this. I spent most of this weekend messing about under the car, changed the sump for one that dose'nt leak, and did some under sealing of the body. I should have taken the engine out to do the sump, wish I had too, what a ******* of a job that was! Also going to find time to fit the locking diff that I picked up this week.
Potsy
Looking good so far Carat, I like your idea's! I'm looking forward to seeing some more progress.
Tell us more about your 3.6 conversion and locking diff.
Sinky
Looking good .
2003 Piaggio X9 Evo
Looking good so far Carat, I like your idea's! I'm looking forward to seeing some more progress. Tell us more about your 3.6 conversion and locking diff. Cheers, I like my ideas too. ;D The locking diff I have got, is an asd unit from a 190e 2.6. Just fitting it to the car without plumbing in the hydraulic system still gives you a 35% lock. These diffs are controled by a computer, that controls the hydraulic system to vary the amount of lockup from 35% to 100%. But the system only works below 19mph, which is no good to me so I am going to convert it to switch between full on and full off by a switch on the dash. The 3.6 conversion I will go into better detail on another day, but it basicly a 300-24 m104 engine, with the bottom end swapped to a c36 amg setup. It moves rather well.
Sinky
What steering wheel is that carat?
2003 Piaggio X9 Evo
Potsy
Looking good so far Carat, I like your idea's! I'm looking forward to seeing some more progress. Tell us more about your 3.6 conversion and locking diff. Cheers, I like my ideas too. ;D The locking diff I have got, is an asd unit from a 190e 2.6. Just fitting it to the car without plumbing in the hydraulic system still gives you a 35% lock. These diffs are controled by a computer, that controls the hydraulic system to vary the amount of lockup from 35% to 100%. But the system only works below 19mph, which is no good to me so I am going to convert it to switch between full on and full off by a switch on the dash. The 3.6 conversion I will go into better detail on another day, but it basicly a 300-24 m104 engine, with the bottom end swapped to a c36 amg setup. It moves rather well. The hydraulic system works from the fluid pressure off the steering pump/resevoir doesnt it? couple of relays in the footwell actuated by the ABs unit i believe. I'm hoping to eventually rid the 2.3 16V LSD and run ASD. Are you going to the gathering, will the 124 be there?
What steering wheel is that carat? Hi mate, I think it made by kaimal and is realy ment for vw's, but it sort of looks period to the car.
Cheers, I like my ideas too. ;D The locking diff I have got, is an asd unit from a 190e 2.6. Just fitting it to the car without plumbing in the hydraulic system still gives you a 35% lock. These diffs are controled by a computer, that controls the hydraulic system to vary the amount of lockup from 35% to 100%. But the system only works below 19mph, which is no good to me so I am going to convert it to switch between full on and full off by a switch on the dash. The 3.6 conversion I will go into better detail on another day, but it basicly a 300-24 m104 engine, with the bottom end swapped to a c36 amg setup. It moves rather well. The hydraulic system works from the fluid pressure off the steering pump/resevoir doesnt it? couple of relays in the footwell actuated by the ABs unit I believe. I'm hoping to eventually rid the 2.3 16V LSD and run ASD. Are you going to the gathering, will the 124 be there? Sadly I wont be at the gathering this year, toooooooo much to do here The asd system does indeed run off the power steering pump, but it is a special twin pump for that job. The car that I took it from had electrical issues with the asd control unit, so I left the relays in it. Just planning to use an on/off switch rather than make it progressive.
