I've got the roof flattened but it's highlighted how thin some of the spraying was but it's great to see it have some reflection in it! I filled the a pillar area it's not the prettiest but it's sealed at least! During the heavy rain yesterday I found out that the garage leaks, this is forcing my hand to epoxy the front out of safety, at least it's done now and allows me to focus on the doors and boot. I've got some rubs because I got too close with the gun - I'll try and work out a way of extending the garage using an awning. I think it's a slightly rougher finish that I'd like - I did thin it more but I'm unsure about air pressure.
1966 Mk1 cortina GT peteh1969
@peteh1969
Club Retro Rides Member 107
Great progress Jim don't worry about runs until you you have it all protected them block sand the whole car.
Jun 12, 2018 20:44:18 GMT
So I've started playing with other panels whilst I concoct a plan to fix the holes in the front wing as it's been tricky to sort. I've focused on the boot lid and some of the door pieces The compressor was running out of puff doing both sides but I'll not hang it this way again as it's a real pain and I'd rather focus on a side at a time. I used the left over primer to brush the inside of the doors before I prepare the outside - looks a bit lame but all the right bits have good coverage Also I cocked up - I removed these pieces from beneath the trim on the c pillar but I have misplaced the drivers side. I'll try to find it but I have a feeling it got caught up in some stuff I threw out. If anyone can help me I'd even buy a pair.
Way to go Jim - some nice progress there - sanding blocks there is a whole range of them - let me know if you are dry or wet sanding and I will come up with some recommendations for you - don't use wood
Way to go Jim - some nice progress there - sanding blocks there is a whole range of them - let me know if you are dry or wet sanding and I will come up with some recommendations for you - don't use wood Thanks Chris, I sent you a message but I went to the local paint supplier and bought the hook and loop block below I've done quite a bit today which was much more preferable than being in the office at work! So there are more low spots than expected but they can be sorted. Shandylegs kindly came over today with his engine crane to lift the engine out - thanks again for your help! Now the engine is out I'll crack in with the inner wings and I made a start on the bonnet too. I've got a few bits to do in the morning- then I'll start filling on the back and sorting the welding/ bare metal work whilst it's curing. I'm going to work out a frame that'll mount where the subframe is so I can remove the front suspension and roll the shell out on castors - it makes sense in my head at least!
Jim - Apologies it's been manic at my end - what the local paint supplier has sold you is exactly what I would have recommended - nice progress too
Jim - Apologies it's been manic at my end - what the local paint supplier has sold you is exactly what I would have recommended - nice progress too No worries Chris, I'm glad I got the right thing! I used 180 grit which I'll also use for the filler and getting the panels straight. What's the best thing for swages and tight areas like the rear panel?
1961 FORD POPULAR 100e 2.0 dohc Mk1 2dr Ford cortina
Jul 15, 2018 20:38:37 GMT
Last Edit: Jul 15, 2018 20:41:26 GMT by jim
Jul 22, 2018 19:48:30 GMT
@peteh1969
Jul 22, 2018 20:06:53 GMT
Very nice work Jim you are making good progress.
Aug 14, 2018 19:53:03 GMT
@peteh1969
Aug 14, 2018 22:05:06 GMT
Nice work that Jim
Important panel there as it helps to take some of the loading from the Anti Roll Bar as well as mounting the bumper.
Aug 26, 2018 20:25:23 GMT
Nothing major to add to the post I'm still working on the front drivers side inner wings. It's a constant battle! There's some areas with underseal I can't reach with either a wire wheel or a scraper and heat so any ideas? I'm not even half way! I've got the other side to do... Also some good news bad news... Good news - I got the c pillar trims! I found a pair on eBay. Bad news - the cellar has flooded (It'll get tanked) so I've had to move some spares out and into the conservatory. Nothing is damaged but the bad news is I heavily under sold how much stuff I store in the house to Mrs. Jim. I'm waiting for sentencing! If anyone can help with the underseal I'd be grateful.
Sept 1, 2018 23:41:37 GMT
Hi Jim
It was good to meet you and have a good natter while pulling the engine out.
As said, great job done to date and good luck with the months of sanding ahead - it will be worth it!
Just caught up with progress: - liking the dollies, they look perfect for the job. - wish I could say the same for the new rot found, but at least itβs now well on the way to being sorted.
Obviously your choice, but Iβd be giving plenty of thought to cutting your dash to fit a din-e type unit (at least save what you cut out so you can put back in at a later date! ππ)
Sept 15, 2018 21:26:31 GMT
Thanks Duncan! I'm going to pop the front off that radio and see if I can use the dash as is and alter the frame of the radio as it's not that sophisticated! I've managed to sort the underside of the wings and it's been a long arduous job especially the a pillar to wing that was excellently moulded tiger seal! I had a break that day to watch the tour of Britain bike race that went past the end of our road I had another look at the passenger wing top where it meets the a pillar, I think it's solid now and just needs a bit of dressing Then back on with the under wings! The welds have been tired! I've also applied kurust as a precaution. And primed - there are a few touch ups needed. It's a massive relief to be at this point as it's been a long slog! During the evenings I've been doing some engine bay work, this is the centre support of the slam panel and I hacked it to get the electric fan to fit and it was flimsy! I've made a good and moulded it at the top to meet the original section - it's come out better than expected which is a shame as it'll never be seen! I made my own set squares! Now I'm onto seem sealing!!!
Sept 23, 2018 15:49:37 GMT
I've seen sealed the underside It's a mix as I was using up the black tube Then I did a buy- 1l of ermine white. Then this happened:
Sept 23, 2018 15:54:41 GMT
Last Edit: Sept 23, 2018 16:05:20 GMT by jim
