Hey Bozwell,,
Good work as always. Can you tell me what make is your front anti-roll bar is?
I need one similar to yours for my Mini!
Cheers Atchi
Building roof chopped, screen raked '68 Mini with G13B 1.3 16v Gti engine with LSD, Yamaha R1 carbs. As well as mk1 Suzuki Swift Gti AWD with a turbo. Drives PHEV Outlander but wishing my mk1 Swift Gti or mk2 CRX Vt were still with me!
Jul 31, 2016 10:58:30 GMT
it's Honda S800.
I still have a spare one if you want it.
Jul 31, 2016 16:11:52 GMT
Cracking build! Thanks for posting
Jul 31, 2016 19:20:45 GMT
Real beauty! Thanks for sharing!
Are two anti-roll bars needed? Surely it doesn't need that much understeer?
Yes, That will be great.
Let me know how much you want for it.
Thanks Atchi
Are two anti-roll bars needed? Surely it doesn't need that much understeer? you forget i'm fitting a heavier engine and the wheel base is shorter than the classic Mini. watch how much lean they have
Anti roll bars won't help with the wheelbase, narrow track maybe
I forget to follow a thread for a while and suddenly it looks like a car Amazing stuff... I love this.
Are two anti-roll bars needed? Surely it doesn't need that much understeer? you forget i'm fitting a heavier engine and the wheel base is shorter than the classic Mini. also depends on the vertical spring rate from the actual coilovers
Aug 14, 2016 19:28:46 GMT
bit tight, going to have to cut the oil filter out engine may have to come out again if the engine mounts move at all for some more clearance modifications but otherwise it's going well.
Aug 14, 2016 21:29:30 GMT
Probably worth just running a remote filter? That's what we have, just a machined disc tat fits on inlet on the block then.
You can probably find a shorter filter easily enough. rycofilters.com.au find your original filter, get the thread and seal sizes, then search those for something suitable (just use vague search terms such as 75-78mm instead of 76mm or it wont find anything). Then cross reference to brand of choice. Seeemples
This is absolutely epic! Tremendous work!
Aug 17, 2016 21:46:24 GMT
cheers. tis tight got to love having a lathe to hand steering needs moving slightly away from the dash and I didn't like the way the centre looked so from this to this looks much nicer
Aug 20, 2016 19:37:13 GMT
1967 Honda S800 F20cstealthstylz
@stealthstylz
Club Retro Rides Member 174
Aug 20, 2016 19:58:01 GMT
Great to see one of my favourite builds coming together. Gonna be superb.
