Nov 20, 2011 21:14:32 GMT
Serious update time!!! Updates Well first we removed the original engine and gearbox (was a heavy lump) We then assembled the CA engine I.e. fitted flywheel, clutch, spigot bush and gearbox Then did a little chopping, well grinding to be fair:- Test fit of the CA, fits quite well using rover v8 mounts its perfect S13 rad and Range Rover P38 intercooler works quite well together Next on the list:- Fabricate the engine mounting points Add some strengthening beams to the new mounts and front subframe. Geabox Mount Intercooler pipework Intercooler mounts Coolant/Heater pipes V-Band elbow/downpipe Exhaust Wiring Loom Swirl pot Fuel hoses Wiring Propshaft Gear Shift Clutch Line + a few more bits I'm sure ;D Many thanks go to the wizard dan for hard work so far
Last Edit: Nov 20, 2011 23:17:00 GMT by deathstar
Nov 20, 2011 21:38:16 GMT
oddly, One of the people on here. "Mystery Machine" used to be a teacher at my school ;D Wait...what?? I started reading this thread with excitment then spotted ^ THAT ^ comment! It wasn't me, honestly. I admit to nothing. It's all lies! (I hate to ask, but which of my poor unfortunate students were you??) Great car, great build and I look forward to seeing more progress. A Sprint on Revos with a CA18DET. What's not to like? Bookmarked.
Nov 20, 2011 21:45:11 GMT
HAHA! James Deacon was in your form group - Terrible student had to work much harder in the real world to get somewhere! you had to split me and david butler up as we were a terrible influence on each other. You had a blue AW11 which I loved seeing outside the school. Had a red aw11 for a couple of years Fair play not sure how you managed it there so many bible bashers
Last Edit: Nov 20, 2011 22:03:31 GMT by deathstar
Nov 20, 2011 22:16:27 GMT
James - I remember you very well (little brother of Hannah yeah??)
Form times were great! Butler was a nightmare, especially when you were mixed up with him - I'm pretty sure you two were responsible for my first grey hairs. I think I even had to talk to your parents to try and keep you two apart. Oh the memories!! I miss you lot but I don't miss the place itself, not in the slightest.
Glad to hear you got an MR2 - cracking cars. Your Dolly is going to be something pretty special - I'm really looking forward to seeing how this progresses. Keep up the good work (that last bit sounds like the end of a school report! LOL)
Nov 20, 2011 23:08:07 GMT
Yeah hannahs little brother Not sure how I ended up a mortgage advisor ;D That last line was like a school report but rather compelling I wont let you down "mr holder" hahaha ill get to the retro rides gathering in it, almost went this year as i know prescott hill pretty well
Last Edit: Nov 20, 2011 23:10:41 GMT by deathstar
Nov 21, 2011 16:15:48 GMT
Futher update. Been speaking to dan about problems and Solutions Fuel supply - Lift lump ( facet) - Then a Jaguar XJS High Pressure pump A swirl pot and then a return to the tank. Battery should fit in the bay fine - They are a small lump No need for a header tank- its built into the nissan rad Misses the BMC Fine. Sump needs to be shorter by 1cm !!!! It will be around 210bhp @6000rpm and max tourqe 190lbft at 4500 RPM with stage 1 chip Steeting coupling is right out the way no issues there. Management ( standard nissan) pig stupid. Loads of sensors but it all goes into the ECU and the ECU itself just needs live and ground and switched live. The only tight spot is the turbo elbow. Gonna go with a V- Band coupling ( comes off the turbo and then down into a 90 degree bend and it should clear with some jigging about - handbrake has had to move back about 2cm otherwise it gets in the way of the prop coupling. The engine is iron block with ally head ( like the sprint engine ) Fans - Twin rover 800 fans ( massive )
Nov 21, 2011 16:56:51 GMT
Great progress there chap!
Nov 21, 2011 17:08:43 GMT
thanks buddy.
Its all going to easy for this conversion!
I see it being copied.
Nov 21, 2011 17:11:44 GMT
I was amazed no one had done it before! Not going to be copied by me at least, not enough spinning triangles for me...
Nov 21, 2011 17:19:50 GMT
Next project might be a rx8 with a sr20
sorry !
Nov 21, 2011 17:33:34 GMT
that sits in there very nicely, thats going to be a monster
Nov 21, 2011 19:49:17 GMT
Will be but better once the LSD in in the car.
More fettling was in order to get the engine sitting right One snag we had was the actuator/turbo was fouling on the suspension turret so we done a little chopping and molding:- Before (albeit on the opposite side) After:- Trial (the engine still needs to be raised up 15mm yet:- In without support of the hoist:-
Nov 22, 2011 15:47:31 GMT
Well I'm now £370 ligher Just bought these SHINEYS!!! Trick speedo that works off the prop bolts to work out the speed - couple of adjustments on the back and you work out a calcuation bobs your uncle. And then I bought the matching rev counter otherwise I wouldnt be able to cope with them not matching! I don't mind - They are retro and shiny
Last Edit: Nov 22, 2011 15:48:44 GMT by deathstar
Nov 22, 2011 19:24:28 GMT
Cool, great work too!
86mike
Nov 22, 2011 22:27:01 GMT
We had a bright yellow Sprint when i was a kid, got a real soft spot for them. Great work.
Nov 23, 2011 10:22:07 GMT
Yellow one! - Might be an early car.
Nov 23, 2011 13:26:42 GMT
More updates from team DB Power garage Updates:- Engine is finally on it's proper mounts Gearbox mount all made Gearbox mount mounted Propshaft time:- I need to make an adaptor so that the rear diff suits the S13 prop flange and then lengthen the rear section of the prop by 98mm I was hoping to use the rear section of the Dolomite prop but I don't thin it will handle the power of the CA Anyhow onwards and upwards Thanks again to Rads S13 and Paul_S13 for their help with this project Dan
Nov 23, 2011 14:02:01 GMT
As for the mount, the gearbox one is 6mm plate with a 4mm angle plate to keep strength Mounts onto the original dolomite holes too The engine mounting plates are 6mm with 5mm right angles, probably ott but I like to over spec if I can Also the engine mounting plates are getting supports added from underneath to help burden the load from the front of the subframe
Copey
crackin conversion! i am just fitting the same motor to my Capri! the dolly will be a right weapon once done!
