Basically this is probably only good for spare parts. The heads were taken off to remove some broken exhaust manifold studs but that was about 5 years ago! Engine may clean up & go again with new gaskets. It does have a 4 speed manual O/D box, Stainless exhaust that should clean up, nice Cobra black vinyl buckets & matching rears, Triumph 14" steel wheels with trims, Salisbury rear axle etc.
Oh, and it`s also Tax free so ideal for a rod base etc.
The headlights & carb are missing, it needs welding to the chassis in an awkward place (body off i`ve been told) and the paint work is naff.
I`ve also got a thread going in the parts section as i`d rather see bits of it going to use.
Located at my work place in Reading.
PM or reply here with geniune enquiries only please.
