madmog
Club RR Member Number: 46
Good source of 3 port valvesmadmog
@madmog
Club Retro Rides Member 46
Jun 19, 2011 20:33:09 GMT
I want the water flow from the heater circuit to always flow back to the engine, whether the heater is on or not. The engine needs this as a design fault means cylinder 4 doesn't get adequate cooling. Ie I don't want to stop the flow back to the engine when the heater is off. I could just T off a permanent circuit for the heater but would prefer to have the heater work well in winter.
So, is there a source of cheap three way valves out there that deal with hot, pressurised water? Best I can come up with is 3 way central heating valves but these have 240V electric solonoid rather than manual lever & I think use a rubber bung to control flow rather than a chrome or stainless steel ball valve. They also cost about £50.
Other alternative is two 2 way valves and remembering to turn one off and one on. This is somewhat clunky though.
Any suggestions? many thanks
Jun 19, 2011 20:58:21 GMT
the ford KA might be worth a look, i think it's 4 port so flows through the valve to the heater when on, but bypasses when off and fluid still circulates via the return hose, control is electric, might be plain on/off but if you used it in conjunction with a flow valve and put a micro-switch to close the valve when you select cold it could do the job cgi.ebay.co.uk/Ford-Heater-solenoid-valve-/120740073495?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c1cab5017#ht_500wt_1156I've heard of people using them on other cars, but also a chap in the trade claimed they only lasted typically about 10yrs on a KA, but on the flip side not expensive either.
Jun 19, 2011 22:07:03 GMT
Vaux Omega heater bypass valve vacuum controlled and I think it does what you want.
Jun 19, 2011 22:47:04 GMT
fiesta/ka ones have a habit of breaking up once been in use for a couple of years never mind 10 years/
theres more to life than mpg & to much power is just enough.
Jun 19, 2011 22:47:21 GMT
fiesta/ka ones have a habit of breaking up once been in use for a couple of years never mind 10 years.
Danfoss HSV3 mid position valves for central heating are available ad the valve only without a solenoid. also the part that controls the water flow appears to be spring loaded metal plates. you can get them on ebay for less than £20 inc.postage.
just happens that I've got one to change on my central heating
Don't become a thief,The government don't like competition.
madmog
@madmog
That's brilliant, thanks guys. I was thinking central heating but couldn't find the 3 way for less than about £45 which is a lot of money to spend when it might not work as an idea.
Jun 20, 2011 12:28:41 GMT
madmog
@madmog
Jun 20, 2011 20:47:47 GMT
Non return valves wouldn't do it, backflow isn't an issue and they don't provide the switch between circuits. I've got a central heating valve and I'll see how that goes. You're one of the Minor guys from the 'other' site aren't you?
I'm currently making a heater out of a Golf matrix and bits of aluminium rivetted together. Should be more effective than the old Minor/Mini one and will fit up in the bulbous bit behind the speedo freeing up the space where the old heater went. I need to update my 'Readers Rides' on here
