gj
Kinda New
hello all!!
I AM NEW HERE !! i have a mk3 capri witch i am working on at the moment and was wondering if anyone knew where or how i could get my hands on a jack up kit for the rear of it i am going for that rad rod type stance !! will put up a build thread soon for you all to see . thanks!!
The traditional way was just longer spring shackles made out of flat steel and if you were posh there were chromed versions. To be honest they looked silly and ruined handling hence going out of fashion. I can't remember if Capri axle was under or over the spring. If over then simply modify to make under and you'd get 4" + of lift. This is often done to 4x4's.
Paul H
bortaf
Jun 18, 2011 16:27:41 GMT
Pretty sure they made jack up kits illegal (the extended shackle ones), capr axle is over the spring so you can flip the springg seats to gain some lift there. Also take into account the castor change at the front will mess with the steering.
R.I.P photobucket
lemon
Gear head
Jun 18, 2011 16:52:15 GMT
Rat rod type stance?
More than it should be, but not as much as it could be
Jun 20, 2011 16:31:01 GMT
Pretty sure they made jack up kits illegal (the extended shackle ones) Did they? Ive googled it, and cant find anything either way??
Current fleet: '58 A35 (half mine) '67 11 window splitscreen vw (half mine) '77 mini 1000 (not quite 1000 any more!!) '86 Armstrong MT500 '89 XR4X4 '94 Corrado VR6 Some sort of sevenesque kit car (no age yet!!) '01 Mondeo estate 2.0 (engine eventually destined for kit car!) - scrapped, engine only left! '98 E300 estate, rusty but seemingly reliable, fast-ish tat hauler. eventual engine donor A35 van, or whats left of it after it lived in a field for many years
capri rear jack up kit!!stealthstylz
@stealthstylz
Club Retro Rides Member 174
Jun 20, 2011 21:50:41 GMT
They made extended spring shackles (extensions welded onto original shackles) illegal iirc - might be best pm-ing Scary Old Cortina to confirm.
They're not difficult to make if you've got half a clue about fabrication.
Matt
Indeed, ive made quite a few sets ove the years, and done a few spring over conversions on sj410/13's etc, just wondered whether or not it was actually illegal......
Actually all of the spring over conversions are illegal, as you have to lengthen the steering arm, which is not allowed to be joined in any way..........
Brian Damaged
West Midlands
Club RR Member Number: 33
Like this you mean? They were just 4 (usually about 9") lengths of 2" wide 1/4" thick steel bar with a hole at one end for the original spring mount and a choice of (usually) three adjustment holes depending on how high you wanted the back end. Usually fitted in conjunction with a painted back axle with a chrome hubcap covering the diff and (the piece de resistance) a couple of auxiliary rear fog lamps mounted underneath and renamed 'cruising lights' (which, if my memory serves me correctly, were often called 'wa*ker lights' by everyone else). Dunno about 'rat rod', this was always a peculiarly British take on the custom scene. Back in the late 70's these sort of mods went hand-in-hand with fur interiors, chain-link steering wheels, pro-stock bonnet scoops, sidepipes and were de rigeur if you were a hot young buck with a Mk1 Cortina and a Richard Grant centre console full of Eagles and Doobie Bros 8-track cartridges. ;D
Illegal? News to me and I'd be very surprised if they were. I made some a while back to lower my Rascal, but the principle is the same....and it cost me next to nothing: £12 for the polybushes and the rest was just made from bits & pieces cut, drilled etc... Details here: retrorides.proboards.com/index.cgi?board=readersrides&action=modifypost&thread=42909&post=854869Should be pretty easy to make some for another car, but just make sure you make them twice as long as the lift you want to acheive.
Jun 21, 2011 10:05:14 GMT
MoT manual ref 2.4.6 (leaf springs) says this but also says To me that says that well made or modified replacement shackles are fine, but dodgy ones aren't. simples
Copey
Jun 21, 2011 11:14:31 GMT
know a lad with a mk1 capri thats got extended shackles on with about 3 sets of holes so he can lower and raise his capri as he wishes, never had a problem with MOTs, they are very much like what Mystery Machine has posted up, nice and simple idea and work perfectly!
bortaf
Jun 21, 2011 12:13:28 GMT
May have wronge there then chaps, i thought i rememberd then being made illeagal same time as spring clamps ?
R.I.P photobucket
Jun 24, 2011 18:34:15 GMT
I thought spring clamps were illigal as they could pop off, or snap springs, and are usually only made to stand compressing a spring for purpose of removal?
id not heard of leaf spring shackles or lowering 'blocks' being illigal, just as long as there used correctly, common sense etc.
2006 Audi A3 2003 Fusion 2 looking for a project....
